ST2000LM005 Donor pcb
asocla
Postby asocla » 02.10.17, 20:06
Hello Guys,I've a USB seagate ST2000LM005, and i'm searching the donor sata pcb.
The Marvell Chip is 88i1025 and the number of usb pcb is 100765396 REV A
Thank you for the help.
Re: ST2000LM005 Donor pcb
Postby DataMedics » 02.10.17, 22:25
I've got a list of SATA compatible USB PCB replacements that I've been keeping here: https://www.data-medics.com/forum/samsu ... t1438.html
However, that one is still on the "unconfirmed" list. So it's a pairing I found mentioned somewhere, but have never actually confirmed that it works myself.
asocla
Postby asocla » 02.10.17, 23:44
i've see your list and i've buy the unconfirmed pcb 100731207.
The unconfirmed board isn't compatible with usb pcb.
I did the test today.
asocla
Postby asocla » 03.10.17, 00:44
After a bit of research I found a compatible pcb. Be No. 100767980. After I'm Shipped, I'll Test You Will Confirm About PCB Compatibility
asocla
Postby asocla » 11.10.17, 23:50
The sata pcb 100767980 is compatible with usb pcb 100765396
Postby DataMedics » 12.10.17, 02:40
asocla wrote:Source of the post The sata pcb 100767980 is compatible with usb pcb 100765396
Thanks! I added that pairing to my running list.
