Hi all,
i have here a ST9100828A with symptoms like pending bug.
Having try another PCB. - not succesful.
Swapping heads. - Same Problem.
Now i tryed "HDD initializion with head map changing in RAM", the result a window with *Error Setting up Protection Block*...
I think this was solved in prior Versions of DE, before any years??
Any sugestions?
Thanks for help
Bruno
Error setting up protection block
Re: Error setting up protection block
And what's the terminal log?
Hi pclab
Thankyou for answer.
Here is the terminal log after starting the util:
Interface task reset
4096k x 16 buffer detected
VENUS - 1_Disk S.01 02
Buzz - -17-06 17:08
Spin Ready
$($0084F,10C88,0000,00,5C,30,80)Switch to full int.
AM Reacquired
(P)$($10C7E,17C89,0000,02,63,50,86)Switch to full int.
AM Reacquired
$($01C9B,10C7E,0000,00,38,08,82)$($01C9B,10C7E,0000,00,3C,14,82)$($01C9B,10C7E,0000,00,3C,14,82)Switch to full int.
AM Reacquired
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
DiskAccess ReadSector EC=43 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
$($10CF0,10CBA,0000,01,42,10,8F)Switch to full int.
AM Reacquired
Failed sys sect. write
$($10CBA,10CEE,005C,00,90,10,81)Switch to full int.
AM Reacquired
PATA Reset
Master
Head Switch Timing Recalibration
AT Er 00 Nwt Er 37 RdWr 084af.02.00af
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f39ff7 be 97f39ff7.1.bd7 0000 005f 0000 d53c
DiskAccess ReadSector EC=43 at 0084af.02.00af
CE Log ErrCode=37 LBA=5f5dead Type=5DiskAccess ReadSector EC=43 at ffffffff.00.0060
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
DiskAccess ReadSector EC=43 at ffffffff.00.0248
AT Er 00 Nwt Er 43 RdWr 084af.02.0165
Niwot: 9ff79ff7 be 9ff79ff7.1.bd7 0000 005f 0000 d53c
DiskAccess ReadSector EC=43 at 0084af.02.0165
CE Log ErrCode=43 LBA=5f5df63 Type=5DiskAccess ReadSector EC=47 at ffffffff.00.0060
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
$($10CF9,0B8AD,006F,02,43,70,79)Switch to full int.
AM Reacquired
AT Er 00 Nwt Er 43 RdWr 084af.02.0167
DiskAccess ReadSector EC=43 at 0084af.02.0167
CE Log ErrCode=43 LBA=5f5df65 Type=5DiskAccess ReadSector EC=43 at ffffffff.00.0060
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
$($10D56,0B8AD,006F,02,43,70,68)Switch to full int.
AM Reacquired
$($1A2AD,0B8AD,006F,02,43,70,55)Switch to full int.
AM Reacquired
$($1A2F2,0B8AD,006F,02,43,6C,86)Switch to full int.
AM Reacquired
$($1A2AF,0B8AD,006F,02,43,6C,86)Switch to full int.
AM Reacquired
$($1A128,0B8AD,006F,02,43,6C,97)
When try head map changing in RAM:
Test : HDD initialization with head map changing in RAM
Test : HDD initialization by utility...
Switch HDD PWR supply.... : No
Terminal Reset........... : No
Terminal work speed...... : 921000
Used LDR................. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Momentus (Venus)\ST9100828A-3-ALA-5LZ0563D\Data\LDR\SgLDR.ldr
Loaded from.............. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Momentus (Venus)\ST9100828A-3-ALA-5LZ0563D\Data\LDR\SgLDR_Utl.ldr
Work with HDD through.... : ATA
App...................... : Loading from LDR
Used modifications....... : Fix 'Pending Bug'
Load Ovl 0............... : No
Initializing Safe Mode...
Switching HDD power supply OFF
Switching HDD power supply ON
App patching...
Downloading App code...
App code downloading.................... : Error
SDLD : transmitted data size not aligned
terminal log when try load cert:
DiskAccess ReadSector EC=43 at ffffffff.00.00a4
INVALID Cert Disk Code - ROM Resident Revision Required: 3.ALA
T>Head Switch Timing Recalibration
Buzz - -17-06 17:08
Spin Ready
AM Reacquired
AM Reacquired
AM Reacquired
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AM Reacquired
AM Reacquired
PATA Reset
Master
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AM Reacquired
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
App patching...
Error after try a Task create, using loader (pending bug), see att. file
- Attachments
- error.rtf
- (2.58 MiB) Downloaded 582 times
Have you checked heads?
It's doesn't seem you have the pending bug here....
Yes i having swapped the heads with same result. Also i changed the PCB, -with same Problem.
Have you checked heads under microscope to check for media damage?
Yes shure, and i have tested the Patient heads in donor drive. Reading without Problem.
I think it is a Firmware Problem, but what??
e.g when i try to save the ROM, after a while i see this: Terminal : error switching to MOS
