ST3500630AS Pending Bug Fix makes certain heads not read
murphman
Postby murphman » 18.08.17, 20:31
So I have a ST3500630AS with what appears to have a pending bug issue.
After I apply the fix I can read perfectly fine except head 1 and 4 wont read AT ALL. Which is strange because they read fine if I DONT apply the pending bug fix. I even tried reading exactly same sector to make sure its not a bad sector..
Could it be degraded heads (I have donor on the way) or it something else? Just very strange because as I said ALL heads read the same if I dont apply the pending fix and then 1 & 4 wont read at all after applying a pending fix.
Your thought?
Thank you
Nick_TS
Re: ST3500630AS Pending Bug Fix makes certain heads not read
Postby Nick_TS » 21.08.17, 22:02
murphman wrote:Source of the post After I apply the fix I can read perfectly fine except head 1 and 4 wont read AT ALL. Which is strange because they read fine if I DONT apply the pending bug fix. I even tried reading exactly same sector to make sure its not a bad sector..
Did you modify the RAM head map when upload App code?
Postby Amarbir[CDR-Labs] » 22.08.17, 11:27
Dmitriy_TS wrote:Source of the post
Dimitry,
In The Blog Article Its Prohibited To Change Head MAP If We Have To Solve The Pending Bug Issue .I Would Expect Some More Blog Articles On ST10 Series Firmware Architecture And Some Terminal Commands Also
murphman
Postby murphman » 23.08.17, 20:37
I havent modified anything.. I saved/made the LDR and then used it to apply the pending fix. Had no reason to modify the head map.. should I have?
Postby Amarbir[CDR-Labs] » 24.08.17, 12:14
murphman wrote:Source of the post I havent modified anything.. I saved/made the LDR and then used it to apply the pending fix. Had no reason to modify the head map.. should I have?
Well,
The answer is No ,This is What I am stating Also Above
Return to “Arch ST10”
