ST3500418AS still loses readiness
AdasRip
Postby AdasRip » 16.08.17, 17:18
I've patient ST3500418AS. Hdd starts and get at the DRD and DSC status for a fraction of a second. Next get BSY status for a few seconds and over and over again.
I can read single sector while hdd has DRD and DSC status.
Log from terminal:
Rst 0x10M
(P) SATA Reset
PASS
RW: Error processing Performance Parameter File: 203C
Send Status: COMRESET seen
Rst 0x10M
(P) SATA Reset
PASS
Rst 0x10M
Nick_TS
Re: ST3500418AS still loses readiness
Postby Nick_TS » 21.08.17, 21:52
Try to uncheck background processes in Edit HDD ID.
AdasRip
Postby AdasRip » 28.08.17, 15:37
It seems that this solution has helped.
Now the hdd restarts every 1 to several minutes but it is enough to copy the sectors.
The copy speed is about 2 MB/s but well that goes.
Thank you veru much.
studiogsm
Postby studiogsm » 14.07.18, 10:01
After uncheck all try to change in Utility status System file reading method to ATA direct and all data read in max speed. That helped for me.
