ST1000LM024 BSY problem
emir_has
Postby emir_has » 15.08.17, 20:02
Model ST1000LM024 momentus-c 5400
It spin up ok but it is BSY status constantly cannot enter in terminal mode. Anyone has experiense with these drives?
How to make him enter in terminal mode which pin to connect?
Maxim_TS
Re: ST1000LM024 BSY problem
Postby Maxim_TS » 15.08.17, 20:58
It's Samsung HN-M101MBB drive, try to run the Samsung utility with Samsung terminal adapter connected, there must be the output in terminal. Show it to us.
emir_has
Postby emir_has » 16.08.17, 18:45
I have made it in samsunh utility as you said and here is the error message thats keep repating.
_ERR:1F90 @00275D010]
[WV015:00275D010:0008 @1]
[CWNotFound] PSN : 0x00C5
[WV_ERR:1F90 @00275D010]
[WV016:00275D010:0008 @1]
[WV017:00275D010:
emir_has
Postby emir_has » 16.08.17, 19:53
Or full log
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 Found
*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 FoundU
S_0SO_1
SU@32'C,5173mV
IS=5
CLA ..36/80
HO..OK
HO RPM=3530 OK
AC 635
ST..Skip..OK
mS1 00000003
GT:415
SC.L:4144/36
BE.N:27
LD..OK
SK C: 7863 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1B
ResoTable Loaded. Rev:0x01
Bump Limit Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Fw Active 00
Ovly loaded to 0x00014D00
Ovly loaded to 0x1002DF30
FdtTable Loaded. Rev:0x02
Unknown file id 384
Up MC
PwrOn RRO1x @ H0
Table) cos = -873216, sin = -197120
Coeff) cos = -283917, sin = 52185
DiskSlip : 126 [SrvTrk]
DiskSlip : 165 [SrvTrk]
0. phs diff 6 [wedges] Table) 206, coef) 200
PwrOn RRO1x @ H2
Table) cos = -868608, sin = -196864
Coeff) cos = -117810, sin = 50045
DiskSlip : 141 [SrvTrk]
4. phs diff 5 [wedges] Table) 206, coef) 201
TgtCyl: 832
Hd: 2 Zn: 0 Avg.:- 316
TgtCyl: 266176
Hd: 2 Zn: 1 Avg.: 871
SVCAL(0080,0000)-->PASS
[H_R:00275CFE8:0000 M:0010 E:1140]
[H_B_RCV]
[GL][ADD:00275CFE8][C:0002][E:7104]
[GL][00275CFE8->315]
[WV000:00275CFE8:0008 @1]
[CWNotFound] PSN : 0x0126
[WV_ERR:1F90 @00275CFE8]
[WV001:00275CFE8:0008 @1]
[WV002:00275CFE8:0008 @1]
[WV003:00275CFE8:0008 @1]
[WV004:00275CFE8:0008 @1]
[WV005:00275CFE8:0008 @1]
[WV006:00275CFE8:0008 @1]
[WV007:00275CFE8:0008 @1]
[WV008:00275CFE8:0008 @1]
[WV009:00275CFE8:0008 @1]
[WV00A:00275CFE8:0008 @1]
emir_has
Postby emir_has » 18.08.17, 08:26
Hi guys
As I mentioned earlier I have made to access Terminal. And the log above I solved on a way that I used command RT (reset) and after executing disk initiziled properly.
Now in DE it shows a lot of "black" sectors! So what is the best way to try read these sectors and recover data???
Masterclass
Postby Masterclass » 18.08.17, 09:52
emir_has wrote:Source of the post what is the best way to try read these sectors and recover data???
Address to ACE help ( open a ticket)
Return to “Spin Point”
