Hi all,
I have a SD card, Lexar, which I got this morning from a customer. The customer said that there is a lot of photo's on the card, but when we put the card in a card reader, it shows that the card is empty. The customer says that he was working on his desktop, accessing the card and then the power went out - it is common here to have power failures. I cannot use the Flash to check the card yet, I need some help with the connections to be able to read it. In the meantime, could a power surge or spike wipe out the contents of the card?
SD card damage.
Re: SD card damage.
It's a typycal Firmware/translator issue. You should unsolder chips and read it with the help of PC-3000 Flash. Then - ask our technical support engineers to help you. Please note - we are not providing technical support on our forum.
