WD smart error
cengizgulum
WD smart error
Postby cengizgulum » 17.07.17, 22:01
Hi everybody
The problem is this: when trying to clean smart , it gives the following error:
The HDD ID:
Model : WDC WD5000LPCX-24VHAT0
Serial : WD-WXF1A86KC19D
Firmware : 02.01A02
Capacity : 500 Gb (976 773 168)
Techno mode key
SA SPT.................................. : 1437
Modules directory address............... : 98 041
ROM Modules:
ROM version............................. : 03.3VJ
ROM F/W version......................... : 0003003V
Overlay F/W version..................... : 03.3WJ
Servo F/W version....................... : B5.0D
Service area:
Permanent overlay....................... : Loaded
Summary Error Log....................... : Feature value set error Device Error Detected: "VSC ERR DRM LOG NOT LOADED"
Summary Error Log....................... : Ok
Self Test Log........................... : Feature value set error Device Error Detected: "VSC ERR DRM LOG NOT LOADED"
Self Test Log........................... : Ok
Other S.M.A.R.T. logs................... : Feature value set error Device Error Detected: "VSC ERR DRM LOG NOT LOADED"
Other S.M.A.R.T. logs................... : Ok
HDD ID reading (RAM).................... : Ok
Thank you to help..
Re: WD smart error
Postby DataMedics » 18.07.17, 18:30
So why are you trying to clear SMART? Trying to "refurbish" and sell on eBay?
cengizgulum
Re: WD smart error
Postby cengizgulum » 19.07.17, 13:25
Yes , I am trying to refurbish it but not to sell it on eBay..
is it impossible to fix ?
Re: WD smart error
Postby Amarbir[CDR-Labs] » 23.07.17, 16:29
Very interested to know from roman and filipp how to solve this i have a similar case at hand
Re: WD smart error
Postby DataMedics » 23.07.17, 18:05
cengizgulum wrote:Source of the post is it impossible to fix ?
Probably not impossible, but certainly not worth the time to just mask a symptom of a failing drive.
cengizgulum
Re: WD smart error
Postby cengizgulum » 19.11.17, 22:15
hello Amarbir,
I solved the problem by applying "slow responding changes cancel" under "work with service area" (! not "work with ram")
fastec
Re: WD smart error
Postby fastec » 24.10.19, 07:59
Weird
I have solved it RESTORING the slow responding changes
except restoring the Relo List (though I don't think it makes difference)
