TOSHIBA MQ01ABD050
Bruno
TOSHIBA MQ01ABD050
Postby Bruno » 27.06.17, 11:48
Hi all,
i have here a strange case with a TOSHIBA MQ01ABD050.
Select Toshiba Utility and switch on the Power.
The hdd spin up and nocking for ~30times. All LED in statusregister where Grey.
Klick the autodetect, the hdd is detectet korrectly,
now start util, the hdd ist clicking for next ~30 times and ERR licgt in red.
Here the log:
ATTENTION!
HDD Is currently locked.
You may use command "Work with service area" / "Password removal" to unlock the HDD.
Techno On............................... : Ok
Zone table.............................. : Ok
Cyl num................................. : 219 226
Head num................................ : 2
Vendor.................................. : TOSHIBA
Model................................... : MQ01ABD100
Microcode............................... : AXF01C1H
G-List reading error.................... : G-List read error; Device Error Detected 01/19 (AMN;<bit3>;INF)
CP Avalable............................. : 33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
I try tu unlock, but no success.
In Modul test i see the cp DD cannot be reed.
Without the P-List i could not be solve PLIST Problem.
Changing the Heads, -same Problem.
So i think the Main Problem is: P-List could not be reed. :x :x
Is there a Chance to recover the data?
Any sugestions?
Thanks for answer.
Bruno
Bruno
Re: TOSHIBA MQ01ABD050
Postby Bruno » 29.06.17, 14:13
Sorry, i forgot to write: Password removal don't work on this drive.
Sergey_TS
Postby Sergey_TS » 30.06.17, 12:14
Bruno, all indications are that heads are damaged here. I suppose you should open this HDD in clean room and check :shockable:
Bruno
Postby Bruno » 01.07.17, 17:37
Hi Sergey
I also came to this conclusion and make a headswap (as i already wrote above "Changing the Heads, -same Problem.")
Only the clicking noise was a bit different, with the new heads.
Maybe the donor heads are not compatible?
The donor hdd is the same type as the patient. Only the firmware is not quite the same.
Patient hdd:
Toshiba MQ01ABD050
Drive Rev: AAH AA00/AX001C
Date: 15AUG2012
Donor drive:
Toshiba MQ01ABD050
Date: 14JUL2012
I will re-install the donor head on Monday, maybe I overlooked something.
I will also install the patient's writing head into the donor hdd to see what happens.
have a nice weekend
Bruno
Return to “Toshiba native”
