Samsung MZ-CPA2560/0A5
tdrc
Postby tdrc » 09.06.17, 21:58
I've mounted this SSD in a SATA Adapter and connected it to the PC-3000, when powered on, it remains Busy. All of the components were tested and the SSD is electronically sound. Appears to be a Firmware issue or Controller Chip failure. I search the board for anything that looked like it could be used to initiate Safe Mode, but nothing stood out.
Controller Chip is S3C29MAX01-Y330
Is this model supported by the SSD utility and is there a way to get this SSD into Safe Mode?
Re: Samsung MZ-CPA2560/0A5
Postby Roman_TS » 13.06.17, 09:14
Hello! Looks like a MacBoock Air drive. I'm right?
Can you attached pictures from front and back side of SSD board? I would like to check something.
tdrc
Postby tdrc » 13.06.17, 18:55
Yes, MacBook Air, Mid-2011
Postby Roman_TS » 14.06.17, 14:08
Here they are:
tdrc
Postby tdrc » 28.06.17, 00:29
The contact points did allow the SSD to reach a ready state during the Loader startup process. The only loader that would load was the 470A_LDR.ldr, which did not allow sector access. The three other options failed to reach the end of the loading process without producing and error. Looks like the current loaders are not compatible with this SSD. Does anyone have a Loader that would work with the above SSD?
Postby Roman_TS » 28.06.17, 11:23
If it possible - please contact Ace Lab TS on ts,acelab.eu.com
We will help you to solve this case.
tdrc
Postby tdrc » 05.07.17, 22:15
The client declined the service and we had to send the SSD back, thanks for the info. Will reach out if I run into another one of these.
bryn
Postby bryn » 07.03.18, 18:16
Roman_TS wrote:If it possible - please contact Ace Lab TS on ts,acelab.eu.com
I have this same drive and same symptoms.
Is there any help available?
Postby Roman_TS » 08.03.18, 09:13
bryn wrote:Source of the post Is there any help available?
14 hours every day, from Monday till Friday without holidays :D
Please contact our TS department, and we will help you with your case.
Postby Amarbir[CDR-Labs] » 23.03.18, 17:49
Haaa Haa,
I could not control myself is not writing :mrgreen: :mrgreen: :mrgreen:
efx
Postby efx » 08.03.21, 21:17
Roman_TS wrote:Source of the post Here they are:
Is it possible to recover data if I have sata adapter but do not have SSD module for pc3000 portable.
Postby Roman_TS » 09.03.21, 08:53
efx wrote:Source of the post it possible to recover data if I have sata adapter but do not have SSD module for pc3000 portable.
Hello! Unfortunately, without PC-3000 SSD you don't have Utilities which allows you to work with internal SSD Firmware. So you should purchase SSD add on first, and then - try to get access to internal firmware, reconstruct damaged parts of it and recover data.
grooovie
Postby grooovie » 13.03.23, 16:39
I have the same problem.
Got in safe mode the 470A_LDR.ldr loader running
but after that it is not possible to recover and no sector edit.
I have PC-3000 UDMA SSD
Postby Roman_TS » 14.03.23, 08:22
grooovie wrote:Source of the post I have the same problem.
Please make a ticket on https://ts.acelab.eu.com/tickets/add/
ACELab engineers will guide you.
Return to “470 Series”
