ST1000DM003 - translator unavailable
AdasRip
Postby AdasRip » 09.06.17, 16:04
I've ST1000DM003 with permanent BSY status. Terminal gives:
Code: Select all
Boot 0x40M
 Spin Up
 Trans.
 Spin Up
SpinOK
 MCMainPOR: Start:
 User Data Base  0043C098
 Check MCMT Version: Factory Init
 MCInitialize: Start:  Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes):
 ClearMC: Start Full  Starting LBA 00009C80, Count 00432418S21(01).
 ClearMC:  Completed, Last LBA 000043C098
 MCInitialize:  MC Cleared
 MCInitialize:  MCTBufferPtr->Header.MCTStateFlags = 0000000A
 MCInitialize:  MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
 MCInitialize:  MCStateFlags = 00000001
 Set MCMT Version Current
[MCMTWS] Tail/Head 0000 0000
 MCInitialize: Init complete:
 MCMainPOR: MCTStateFlags 00000022  MCStateFlags 00000041  Tms 0000379C PASS
SP200: MSPMainPOR Start
Starting LBA of RW Request=0000000000  Length=00000138
ProcessRWError -Read-   at LBA 0000000000  Sense Code=43110081
ERC TO exceeded, orig value in us:FFFFFFFF
 MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000000
 MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000000
 MSP Reconstruction: EXCEPTION: Read MSP Segment Error
     Segment 0000 StartLBA 00000000  ErrorLBA 00000000
     Error in MSP Header
     Continue MSP Read, PreError Segment Cnt0000
     Num Segments 004E
Starting LBA of RW Request=0000000004  Length=00000134
ProcessRWError -Read-   at LBA 0000000004  Sense Code=43110081
 MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000004
 MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000001
     Segment 0001 StartLBA 00000020  ErrorLBA 00000020
     Error in MSP Header
     Num Segments 004E
    Starting LBA of RW Request=0000000134  Length=00000004
ProcessRWError -Read-   at LBA 0000000134  Sense Code=43110081
 MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000134
 MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000004D
     Segment 004D StartLBA 000009A0  ErrorLBA 000009A0
     Error in MSP Header
     Num Segments 004E
 MSP MainPOR: 00001000  Tms 0000379C  0001644D  00019CA9
 MSP MainPOR: Complete
No HOST FIS-ReadyStatusFlags 0002A1A1
I did a resistance head test: H0: 0175, H1: 012D.
I tried to backup system files to repair the translator but during copying the translator the process stops.
The rest ie P-list, NRG, HDDID are downloaded corectly.
Can I perform a translator remover in this situation?
Maxim_TS
Re: ST1000DM003 - translator unavailable
Postby Maxim_TS » 26.06.17, 21:15
AdasRip, looks like the translator is damaged on the surface.
Try to read the translator sysfile with error ignoring by both copies separately.
If you read it, try to write the good translator in one or both SA copies.
Maxim_TS
Postby Maxim_TS » 26.06.17, 21:17
If you can't read it or restore from parts, write the translator from same model and FW donor.
Then regenerate it.
If there are no physical bad sectors in translator, it might work.
But check if heads can write first
