After the 6.3 update, I'm DE is commonly reporting cloning processes as 'broken' instead of 'complete' ... a majority of the time I think.
Is this just a glitch, or does it indicate something?
My normal method of cloning is to first build maps of the desired files, sort to sequential order, then clone the selection. I'm not sure if I've seen it occur when just cloning normally without selectivity. I have never seen this before the 6.3 update.
"broken" in DE operation status section instead of "complete"
- digitalsupport
- User
Re: "broken" in DE operation status section instead of "complete"
+1 I also noted that.
But no errors, tried the same job on 6.2 where the final masseage is "complete"
- digitalsupport
- User
This issue is solved in DE 5.6.4
