SDTNQCAMA_016G
Typical Flash recovery cases
minea
SDTNQCAMA_016G
Postby minea » 19.05.17, 08:59
Hi. I have a little problem with USB flash : no name 16gb, SDTNQCAMA_016G cbm2098. I can't make ecc corection. Is there any solution?
Re: SDTNQCAMA_016G
Postby Roman_TS » 19.05.17, 09:06
It's a controller with dynamic XOR. Anyway, it's possible to solve it using dynamic XOR pattern for CBM2096\2098
minea
Re: SDTNQCAMA_016G
Postby minea » 19.05.17, 10:21
Ok. Thx. But first i will delete bad columns?
minea
Re: SDTNQCAMA_016G
Postby minea » 19.05.17, 13:17
I still have a question, xor have to choose in data preparation / dynamic xor? But who is that good? How do I pick it up later to remove bad columns? Or before xor? Sorry for my English, I'm learning it. :)
Re: SDTNQCAMA_016G
Postby Roman_TS » 22.05.17, 10:09
If your chip is TLC (block size is 192, 258 or 516 pages), then you should check the Bad Columns first - they might be in your case. More about Bad Bytes you can read here:
http://blog.acelab.eu.com/how-to-de ... -dump.html
Dynamic XOR should be applied from Dynamic XOR string in Data Preparation. Your dynamic XOR should have the same Block size and the same Page size, as the XOR from the list.
