I'm trying to find a heads donor for this drive among SATA drives. Just got exact the same one with USB PCB, but if those heads fail is there any alternative?
Drive has 6 heads so it's a little taller than normal drives.
WD10TMVW-11ZSMS4
DCM:HHMT2BBB
Any tips?
WD10TMVW-11ZSMS4 head donor help
Re: WD10TMVW-11ZSMS4 head donor help
Hello SGdata, Lookf for the close DCM and same family, head map, date and country donor drive.
Does these infos include heads number? My question was is there a SATA version of this drive. With 6 heads.
Dear All;
I am new for PC-3000 UDMA
when I star using the utility I got such error message
HDD MODEL: WD blue WD10JPVX-60JC3T0
Techno mode key
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules directory address............... : 183 696
ROM Modules:
ROM version............................. : 16.14G
ROM F/W version......................... : 00160014
Overlay F/W version..................... : 16.14G
Servo F/W version....................... : NA.18
Service area:
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActPdFail
SA dir reading (ABA/CHS)................ : Techno key error; unexpected error: Operation aborted
Could you please help me to understand and solve the problem
Techno mode key
ROM Modules:
Service area:
P-List reading.......................... : Module ID 33 reading error Data request error Device Error Detected: "Unknown error code: 3746"
G-List reading.......................... : Module ID 34 reading error Data request error Device Error Detected: "Unknown error code: 3746"
T-List reading.......................... : Module ID 36 reading error Data request error Device Error Detected: "Unknown error code: 3746"
Relo-List reading....................... : Module ID 32 reading error Data request error Device Error Detected: "Unknown error code: 3746"
