I need help with WD20NMVM-11EDZS2.
I replaced USB-3 PCB to Sata PCB with Rom desolder.
If i start utility "HDD is locked" both, open hdd or remove password it does not work. Drive is locked by WD Software and i know the password.
How can i access the data?
WD20NMVM-11EDZS2
Re: WD20NMVM-11EDZS2
Have i do unsolder U14 too?
i have solved the problem:-)
i follow the blog entry http://blog.acelab.eu.com/pc-3000-f ... drive.html step by step.
first mistake was , i forgot the decryption check box at DED-task.
lka124 wrote:Source of the post i have solved the problem:-)
Its called SED " Self Encrypting Drive "
yes i know, but client have also uses WD Software with another password
