SanDisk SD6PQ4M 88SS9183-bnp2
recovery
Postby recovery » 06.04.17, 10:58
We received this SSD:
Customer said the drive is not seen in BIOS.
We cannot find any adapter to connect it to the PC3000. We found an adapter to work with a Tableau write blocker, but the SSD is not seen in the Windows config panel.
Do you have an adapter for this drive? How can we deal with these SSD?
Re: SanDisk SD6PQ4M 88SS9183-bnp2
Postby Roman_TS » 07.04.17, 18:10
Hello. We can deal only with MacBook AIR 2010-2012 Apple SSD based on Samsung controllers. Marvell controllers are not supported + modern SSD starting from 2012 does not contain SATA controller - only PCI-E, so it's impossible to connect it though SATA.
sempre
Postby sempre » 17.03.21, 20:03
recovery wrote:Source of the post Hello,
Hello!
Sorry, please I have the same problem found a solution for your case?
nothing is impossible!
Postby Roman_TS » 18.03.21, 08:45
This is AHCI PCIe Apple SSD.
In case of a logic issue with file system, bad sectors, hanging or freezing, you can try to use PC-3000 Portable III to read it. Power supply setting, ACELab driver and other internal bus and reading algorithm optimizations will help you to read this device.
In case of a serious firmware corruption, not sure that you will be able to recover it.
More please read here:
https://blog.acelab.eu.com/pc-3000-port ... pters.html
Return to “Other SSD”
