Can someone provide detailed instructions on how to do an LDR Upload and will it help fix the issues under Service area?
Here is the output that prompted me to seek help:
Techno mode key
Cyl Count............................... : 170
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR
Upload is recomended"
ROM Modules:
ROM version............................. : 05.2NA
ROM F/W version......................... : 0005002N
Overlay F/W version..................... : 05.2NA
Servo F/W version....................... : 04.2G
Service area:
SA dir reading (ID)..................... : DISK DAM ERROR
SA dir reading (ABA/CHS)................ : Dir reading error ABA 222 870(1) reading error Physical read error C/H/S: -170/1/1
Device Error Detected: "DISK DAM ERROR"
Thanks for your help.
WD25000AAJS-75B4A0
Re: WD25000AAJS-75B4A0
caputlatinum, It's a Pinnacle drive, so I moved the topic to Marvell.
The loader will not help if heads are bad.
Try to edit the head map in RAM: http://blog.acelab.eu.com/ram-head- ... -case.html
