How to important one .FDB Database to another Database?
zeroalpha
Postby zeroalpha » 05.04.17, 12:34
Hello World!
What is the best way to import the contents of a PC3000 database file .FDB to a different PC3000?
I want to merge the database files from all my PC3000 into one super database.
Re: How to important one .FDB Database to another Database?
Postby digitalsupport » 06.05.17, 12:36
On each top level folder in your DB you can "add folder into export list"
Then import files in your super DB, maybe you should set up a DB server and connect all your PC3000 to that.
Postby Amarbir[CDR-Labs] » 07.05.17, 11:11
zeroalpha wrote:Source of the post Hello World!
How many pc3k stations you have
zeroalpha
Postby zeroalpha » 18.05.17, 06:31
digitalsupport wrote:Source of the post On each top level folder in your DB you can "add folder into export list"
OK. Was hoping for a more simpler method :)
