SEAGATE ST500LT012 No terminal access
hddr49
Postby hddr49 » 06.02.17, 16:46
Hi buddies !
I've got this ST500LT012 with no access to terminal.
Symptoms :
Code: Select all
Boot 0x10M
 FAIL  Servo Op=0100 Resp=0007
 ResponseFrame 0CD1 37CC 0000 0000 0000 D7F8 0000 FF98 0000 0001 0000 0000 0000 0000 0000 0000 A616 FFF8 C2B7 777C 88F2 8CC1 5D90 15F5 E837 C2C2 B811 059A E3DD 1DA3 8CEA 5994 0000
 FAIL  Servo Op=0100 Resp=0003
 ResponseFrame 0000 37E4 FFFF 0000 0000 D7CA 0039 FF97 0000 0003 0000 0000 0000 0000 0000 0000 A616 FFF8 C2B7 777C 88F2 8CC1 5D90 15F5 E837 C2C2 B811 059A E3DD 1DA3 8CEA 5994 0000
Spinup Failure
ServoLoopCode=0x0000007F
It detects Model, S/N Fw but shows 3.86 GB
I need to reach access to terminal to go further.
I have a copy of ROM
FW is 1003YAM1
I try to short pins, but no success at all.
do you have any advices for me ? same FW perhaps ?
What can I check in ROM ?
Thanks.
Re: SEAGATE ST500LT012 No terminal access
Postby DataMedics » 06.02.17, 18:46
Looks like bad read/write heads to me. I'd start with fixing that.
hddr49
Postby hddr49 » 09.02.17, 09:57
Hi, I check heads visually, but I don't see anything wrong.
I recieve donnor in few days, I will see...
Postby gameboybin » 10.04.25, 10:41
I am having the same exact issue. The issue stays the same after head swapping
