Is it possible to edit this head map? Is this normal? Or does it looks like this because it's not supported yet?
Thanks,
Brian
Sergey_TS wrote:300ddr, Yes, this is drive is not fully supported thus Head map looks strange via 'NV-RAM visual editing' (but it's not the sign of damage).
Correct Head map is located by 0x690 Offset for this model. So you can try to change it manually for checking damaged head.
