Toshiba MQ01ABD100H can''t read sectors
odedshankar
Postby odedshankar » 31.01.17, 06:29
Hi Folks,
I have a Toshiba MQ01ABD100H which identified properly, but i can't read any of the sectors.
When reading the CP modules, there was one error - CP FE failed to read.
Would love to hear any suggestions or if someone had some experience with a similar case.
Is it possible to write an FE module from a donor drive or re-generate it somehow?
Cheers
odedshankar
Re: Toshiba MQ01ABD100H can''t read sectors
Postby odedshankar » 31.01.17, 06:33
B.T.W - I already tried the Toshiba Translator Regeneration and it didn't work:
viewtopic.php?f=147&t=7732
lcoughey
Postby lcoughey » 31.01.17, 14:35
when you mirror in DE, do you choose to read via utility with corrupt g-list option?
odedshankar
Postby odedshankar » 31.01.17, 21:49
yes, did that and it but still all sectors are not read properly - all yellow - it works in most of the cases but this one is quite unique
Filipp_TS
Postby Filipp_TS » 13.02.17, 13:10
As you can see in model name of this drive - it's SSHD drive, and probably it have a problem with the NAND - so, try to switch off NAND and you get an access to users area.
odedshankar
Postby odedshankar » 14.02.17, 04:29
thanks Filipp, I'll update to the new version and give it a go.
Return to “Toshiba native”
