Create heads map in WD USB
Continuum
Postby Continuum » 20.01.17, 01:06
Is there a way to create a heads map in a WD passport?
I have one bad head, and i need to disable it so that I can read data from the other heads.
Any suggestions?
thanks
Re: Create heads map in WD USB
Postby Amarbir[CDR-Labs] » 23.01.17, 17:27
If You can enter Tecnho Utility In Software Then You Can Lanuch DE And Make a Head Map , Otherwise you Need To Convert To SATA And Then Do Exactly The Same Steps
Return to “WD USB”
