Hello all,
I have a drive that times out when trying to read the P-List and G-List, and on a Resources backup it also times out when reading CP DD (It wont read anything after that since it times out). I have tried everything i can think of, so any help would be appreciated! I also have gone through a large majority of the posts here, and tried all fixes except the terminal port fix.
Drive notes: Drive clicks about 7-8 times then spins down. This only occurs when trying to get info from the drive like ID, data extraction, etc.
Drive Information:
Model : TOSHIBA MK6014GAL
Serial : 387CSCXUS
Firmware : BV106G0
Capacity : 37.25 GB (78 126 048)
Log Readout:
Techno On............................... : Ok
Zone table.............................. : Ok
Cyl num................................. : 75 192
Head num................................ : 2
Vendor.................................. : TOSHIBA
Model................................... : MK6014GAL
Microcode............................... : BV106G0
G-List reading error.................... : G-List read error; Data transfer timeout
CP Avalable............................. : 33,34,44,56,91,92,93,94,95,97,98,9A,9B,9C,A2,A9,AA,AF,B4,BB,C1,CC,DD
Moving G-List to P-List
G-List read error; Drive is not ready
NN * Head 0 * Head 1
NN * Beg Cyl : End Cyl : SPT * Beg Cyl : End Cyl : SPT
00 * 0 : 2 079 : 1 028 * 0 : 2 079 : 1 028
01 * 2 080 : 4 159 : 1 020 * 2 080 : 4 159 : 1 020
02 * 4 160 : 6 239 : 1 012 * 4 160 : 6 239 : 1 012
03 * 6 240 : 8 319 : 1 008 * 6 240 : 8 319 : 1 008
04 * 8 320 : 10 399 : 1 000 * 8 320 : 10 399 : 1 000
05 * 10 400 : 12 479 : 990 * 10 400 : 12 479 : 990
06 * 12 480 : 14 559 : 980 * 12 480 : 14 559 : 980
07 * 14 560 : 16 639 : 972 * 14 560 : 16 639 : 972
08 * 16 640 : 18 719 : 960 * 16 640 : 18 719 : 960
09 * 18 720 : 20 799 : 940 * 18 720 : 20 799 : 940
10 * 20 800 : 22 879 : 924 * 20 800 : 22 879 : 924
11 * 22 880 : 24 959 : 910 * 22 880 : 24 959 : 910
12 * 24 960 : 27 039 : 900 * 24 960 : 27 039 : 900
13 * 27 040 : 29 119 : 876 * 27 040 : 29 119 : 876
14 * 29 120 : 31 199 : 864 * 29 120 : 31 199 : 864
15 * 31 200 : 33 279 : 840 * 31 200 : 33 279 : 840
16 * 33 280 : 35 359 : 828 * 33 280 : 35 359 : 828
17 * 35 360 : 37 439 : 810 * 35 360 : 37 439 : 810
18 * 37 440 : 39 519 : 792 * 37 440 : 39 519 : 792
19 * 39 520 : 41 599 : 774 * 39 520 : 41 599 : 774
20 * 41 600 : 43 679 : 756 * 41 600 : 43 679 : 756
21 * 43 680 : 45 759 : 740 * 43 680 : 45 759 : 740
22 * 45 760 : 47 839 : 720 * 45 760 : 47 839 : 720
23 * 47 840 : 49 919 : 720 * 47 840 : 49 919 : 720
24 * 49 920 : 51 999 : 692 * 49 920 : 51 999 : 692
25 * 52 000 : 54 079 : 674 * 52 000 : 54 079 : 674
26 * 54 080 : 56 159 : 660 * 54 080 : 56 159 : 660
27 * 56 160 : 58 239 : 640 * 56 160 : 58 239 : 640
28 * 58 240 : 60 319 : 620 * 58 240 : 60 319 : 620
29 * 60 320 : 62 399 : 600 * 60 320 : 62 399 : 600
30 * 62 400 : 64 479 : 580 * 62 400 : 64 479 : 580
31 * 64 480 : 66 559 : 560 * 64 480 : 66 559 : 560
32 * 66 560 : 68 639 : 540 * 66 560 : 68 639 : 540
33 * 68 640 : 70 719 : 520 * 68 640 : 70 719 : 520
34 * 70 720 : 72 799 : 504 * 70 720 : 72 799 : 504
35 * 72 800 : 74 879 : 480 * 72 800 : 74 879 : 480
36 * 74 880 : 74 911 : 1 028 * 74 880 : 74 911 : 1 028
37 * 74 912 : 75 191 : 1 028 * 74 912 : 75 191 : 1 028
Physical capasity....................... : 118 285 440
Avalable capacity....................... : 78 126 048
Soft reset ...
Resource master copy creation in DB
Reading CP
Into DB folder.......................... : /-/CP
CP 33................................... : Ok
CP 34................................... : Ok
CP 44................................... : Ok
CP 56................................... : Ok
CP 91................................... : Ok
CP 92................................... : Ok
CP 93................................... : Ok
CP 94................................... : Ok
CP 95................................... : Ok
CP 97................................... : Ok
CP 98................................... : Ok
CP 9A................................... : Ok
CP 9B................................... : Ok
CP 9C................................... : Ok
CP A2................................... : Ok
CP A9................................... : Ok
CP AA................................... : Ok
CP AF................................... : Ok
CP B4................................... : Ok
CP BB................................... : Ok
CP C1................................... : Ok
CP CC................................... : Ok
CP DD................................... : CP Reading error; Data transfer timeout
Resource master copy creation completed
Physical capacity....................... : 118 285 440
Soft reset ...
Soft reset ...
Soft reset ...
Hard reset ...
Defect list reading
Table................................... : P-List
File.................................... : <HDD Profile>\Defects\PList.chs
CP Reading error; Drive is not ready
I am fairly certain it can be solved with replacing the bad CP's, however im not 100% sure.
Toshiba MK6014GAL CP Issues
Re: Toshiba MK6014GAL CP Issues
As you know P-list is unique on each drive and it can't be replaced from other drive/profile.
Do you need a data recovery or fix the drive?
If you need a Data Recovery - then read via Active utility with "Solve G-list problem" active option.
If you need to fix the drive - then launch a Factory reset option (User data will be lost forever).
dsolutions wrote:Source of the post Moving G-List to P-List
