What is the procedure to add defects into P-list?
ictsec.areait
Postby ictsec.areait » 19.01.17, 09:07
I've read some articles in the blog but I was unable to obtain any success.
What I did is a surface test, remove interactions and intersection, add defects into P-list and regenerate translator.
After turning off the hard disk and re-run the utility I do another surface test and I get the same defects, it's seems to me that anything is changed into P-list. :shockable: :???:
What is the correct procedure to add defects into P-list?
Thanks in advance :)
Maxim_TS
Re: What is the procedure to add defects into P-list?
Postby Maxim_TS » 19.01.17, 13:44
ictsec.areait, try to hide the defects not by sectors, but by tracks into P-List. Also clear Relo-List and G-List.
Postby Amarbir[CDR-Labs] » 23.01.17, 17:28
Maxim_TS wrote:Source of the post ictsec.areait, try to hide the defects not by sectors, but by tracks into P-List. Also clear Relo-List and G-List.
Max ,
Also Necessary to Zerofill Drive After Such Procedure
Return to “Discussion club”
