Module (0001) read error
mscerl
Postby mscerl » 07.11.16, 07:26
I have a MyPassport drive and tried to connect it via sata interface. After blocking SA access, i tried to "Upload dir into the HDDRAM " but i got this error : "Module (0001) read error Module ID 01 reading error Data request error - Drive is not ready ".what's the problem and how could it be solved?
Garry_TS
Re: Module (0001) read error
Postby Garry_TS » 07.11.16, 08:30
Problem is that module 01 can't be readed :D
Possible reasons:
1. Module 01 is damaged. Try to upload LDR from resources and run SA module checking. If you will find that 01 is damaged you can rewrite it from same firmware.
2. Module 01 is on a wrong location. Check this article.
3. Surface is unreadible. If after LDR uploading you won't get SA access - try to install donor heads.
mscerl
Postby mscerl » 07.11.16, 12:19
Thank you
Return to “WD USB”
