The following English, Japanese and Chinese software updates for PC-3000 and DE are released today:
PC-3000 Express/UDMA-E/Portable Ver. 6.2.18
Data Extractor Ver. 5.5.2
Data Extractor RAID Edition Ver. 5.5.2
PC-3000 SSD Ver. 2.3.1
Keeping the tradition of constant perfection, ACE Lab developers have significantly enhanced the functionality of the PC-3000 and Data Extractor software. Wider range of supported drives, more supported file systems, greater possibilities for working with encrypted partitions – you will find all these features and a lot more in the new Update!
SHORT LIST OF THE MAIN ENHANCEMENTS:
PC-3000 & Data Extractor
Added support for very old HDD (10+ MB) working via CHS/LCHS addressing
Implemented new simplified launcher interface
Data Extractor
Enabled working with encrypted partitions Windows Bitlocker, Apple FileVault, TrueCrypt
Added ZFS file system support
Added BtrFS file system support
Added "Apple Virtual disk" (DMG) virtual drive support
Added metadata scanning method MDADM for partitions of $FD type and GPT slots of "Linux Raid" type
Added autodetection based on AppleRAIDHeader
Added autodetection and possibility to create RAID-Z(1,2,3)
WDC Marvell
Added automatic 03 module recovery mode
Added ARCO tests
Support of new decrypting algorithm for Western Digital HDD
Samsung
Added Burn-tests for M8E, F4, F4_3D families
Hitachi-IBM-ARM
Added Loader (Download Microcode, ATA cmd 92h) loading function
Added "Write to RAM" and"Edit head map in ROM" modes
Hitachi GST (SAS)
Enabled editing HDD ID info (Model, S/N, Sector size, WWN, Date of Manufacture and other)
Toshiba
For hybrid HDD added Nand Flash support
PC-3000 SSD
SanDisk Marvell
Added support for new types of storage: SanDisk X300, SanDisk Ultra II
Silicon Motion
Added PNY CS1111 support
Added AMD Radeon R3 support
Added ADATA SP550 support
Enabled automatic re-reading of pages using ReadRetry
Added support for drives with two LUNs per chip
Enabled WWN edition
Marvell VanGogh
Implemented support for new translator formats for Crucial M4, Micron C400 (256/512 Gb) drives
Intel Postville
Translator creation mode has been significantly improved
More details you can read here.
The newest versions of PC-3000 are available now!
Re: The newest versions of PC-3000 are available now!
Well,
I was thinking you folks might have nailed the Phison 3110 S10 controller .Can we have some time frame for that .Lot of devices on this controller These days
Are there instructions anywhere yet on how to work with filevault drives with 6.2, or is it relatively automatic? (I just received one that clones perfectly, but doesn't prompt on the MacOS to mount with a password, though DE sees that it's using filevault).
Right-click on FileVault partition and select "map". Click on down arrow on top toolbar (to the left of the square grid). Select "add virtual drive."
Then select "add virtual drive (Encrypted)". A dialog box will open prompting for FileVault password. By the way, don't give me credit for figuring this out myself. Tech support gave me the info. Good luck.
We need some kind of manual update for these new things too.
Will it be released?
- thatdellguy
Amazing update! Thanks Ace team for all the hard work.
Is the Marvell 88SS9188 controller supported?
I have a Sandisk X300S SD7TN3Q with this controller.
I'm working on a sandisk X300s SD77S83Q-128 with marwell controller 88SS9188, drive ID 0.5MB only.
Any idea?
Thank you!
Any idea?
Thank you!
