Recovery from Raid 6 without RAID Recovery
dsolutions
Postby dsolutions » 26.09.16, 23:33
We have a client that is requesting a RAID recovery: A RAID-6 utilizing 12 hard drives. Is it possible to recover data from these drives without having the RAID addition to the PC-3000? We have the PC-3000 with the Data Extractor. Thanks! :D
Re: Recovery from Raid 6 without RAID Recovery
Postby Amarbir[CDR-Labs] » 27.09.16, 10:09
dsolutions wrote:Source of the post We have a client that is requesting a RAID recovery: A RAID-6 utilizing 12 hard drives. Is it possible to recover data from these drives without having the RAID addition to the PC-3000? We have the PC-3000 with the Data Extractor. Thanks! :D
Well,
First Clone Of Image All 12 Drives .If You Find a Physically Failed Drive Solve the Issue And Proceed .Then You Can Use UFS Explorer / Rstudio Etc To Reconstruct The RAID
lcoughey
Postby lcoughey » 27.09.16, 17:34
Based on the fact that you asked the question, you aren't likely to be successful with a RAID6 recovery on your own. Start cloning the drives and line up someone who can assist you remotely.
Postby DataMedics » 03.10.16, 22:17
It really depends on whether or not it's a standard RAID or some proprietary type of RAID 6. If it's a pretty typical controller which uses Reed Solomon parity calculations, then you can do it using R-Studio and a lot of know how. If it's something special like an EMC SAN unit, then you're in a totally different boat.
Return to “Data Extractor”
