Seagate ST3500320NS terminal
vaidis1973
Postby vaidis1973 » 25.09.16, 21:05
Have ST3500320NS with firmware SN06, PCB: ZKAJ-7 100475720 Rev A, from terminal no response, like terminal turned off. Same PCB with firmware SN04 work with terminal.
PCB REV C with firmware SN06, terminal work ok too.
What shamanic techniques need to unlock terminal ? Unscrew pcb from motor, or chanell shortcut dont help :(
thx
msurgeon
Re: Seagate ST3500320NS terminal
Postby msurgeon » 26.09.16, 17:04
First, have you already copied the patient ROM to one of the donor boards? Do you get terminal output after doing this? If not, try copying patient adaptive data (CAP+RAP+SAP+IAP) from ROM to donor board with SN06 firmware. Any change?
Postby Amarbir[CDR-Labs] » 26.09.16, 17:19
msurgeon wrote:Source of the post First, have you already copied the patient ROM to one of the donor boards? Do you get terminal output after doing this? If not, try copying patient adaptive data (CAP+RAP+SAP+IAP) from ROM to donor board with SN06 firmware. Any change?
Does That Mean If We Are Able To Copy Adaptives From Currupt ROM Properly We Can Use Same Firmware Alternative ROM And Inject Adaptives To That It Will Make The Drive Function ? .
msurgeon
Postby msurgeon » 27.09.16, 00:53
Correct. Of course this assumes that the problem is not with the adaptive data itself.
Postby Amarbir[CDR-Labs] » 27.09.16, 10:08
msurgeon wrote:Source of the post Correct. Of course this assumes that the problem is not with the adaptive data itself.
Well,
It Would Be Nice Researching On Seagate ROM After Few Days Will Keep in Touch
vaidis1973
Postby vaidis1973 » 27.09.16, 11:17
msurgeon wrote:Source of the post copied the p
I resold with other PCB. bacause terminal dont work i cannot read ROM, only with programmer.
I already read and need inspect content
vaidis1973
Postby vaidis1973 » 03.10.16, 18:39
nothing good :(
FlashLED - Failure Code:000000cc Failure Address:0025c5f7
or
F3 2>Z
Spin Down Complete
Elapsed Time 0.130 msecs
F3 2>U
Error 1009 DETSEC 00006008
Spin Error
Elapsed Time 13.911 secs
R/W Status 2 R/W Error 84150180
F3 2>
