WDC WD20NMVW-11AV3S3 HDDs RAM reading error
baldric
Postby baldric » 17.09.16, 11:53
Hi Sir,
I have this hard disk for data recovery.
The drive had a dropped and after that able to accses user data but read very slow (10-30kb/s)
But i manage to copy out the hdd resources (rom and module)
so i try to do the solve slow responding problem.
http://blog.acelab.eu.com/pc-3000-h ... oblem.html
at step No. 2 i notice my WD 2.5" 2TB drive should have 8 heads,
but my PC3000 screen shows only 2 rows of address.
at step no. 5 , my log has an error :
Techno mode key
Modules directory address............... : 318 137
ROM Modules:
ROM version............................. : 21.2CH
ROM F/W version......................... : 0021002C
Overlay F/W version..................... : 21.2CH
Servo F/W version....................... : N0.38
Module (0011) read error Module ID 11 reading error Data request error - Drive is not ready
after which, the drive ID become not able to auto detect.
I changed a new head into the drive.( the head has a known head 0 can read cannot write, head 1 can read/write)
I'm still getting the same error.
I try to load the modules from the previously backup from this drive, i cannot access the drive.
If I load ldr 11.rpm as permanent overlay from a downloaded resource from hddguru website, i can read the front few user sector.
if i jump to final sector, the drive will become busy forever.
if i go to data extraction. The drive will reinitialise and my drive become unable to detect.
My modules also have problem :
Modules checking
Module 01............................... : Ok
Module 35............................... : Ok
Module 12E.............................. : Ok
Module 102.............................. : Ok
Module 103.............................. : Ok
Module 104.............................. : Ok
Module 105.............................. : Ok
Module 106.............................. : Ok
Module 108.............................. : Ok
Module 02............................... : Ok
Module 1B............................... : Ok
Module 411.............................. : Ok
Module 2F............................... : Ok
Module 2A............................... : Ok
Module 21............................... : Ok
Module 23............................... : Ok
Module 24............................... : Ok
Module 11............................... : Module reading error: ABA 320 028(1) reading error - Device Error Detected: "Unknown error code: 51AD"
Module 50............................... : Ok
Module 51............................... : Ok
Module 52............................... : Ok
Module 53............................... : Ok
Module 109.............................. : Ok
Module 6E............................... : Ok
Drive is not ready
Module 116.............................. : Module reading error: ABA 13 884(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 118.............................. : Module reading error: ABA 13 890(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module AC55............................. : Module reading error: ABA 321 113(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 4002............................. : Module reading error: ABA 321 114(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 6D............................... : Module reading error: ABA 321 115(1) reading error - Drive is not ready
Drive is not ready
Drive is not ready
Module 122.............................. : Module reading error: ABA 321 116(1) reading error - Drive is not ready
Drive is not ready
Anyone can help on this?
Maxim_TS
Re: WDC WD20NMVW-11AV3S3 HDDs RAM reading error
Postby Maxim_TS » 20.09.16, 09:39
baldric,
Try to set the region 1 address instead of 0 in region 0 address first in ROM. Restart the drive.
Then try to upload the loader into RAM, get SA access, and solve the Slow Responding problem once again.
Also it can be necessary to clear the module 02: http://blog.acelab.eu.com/pc-3000-h ... rives.html
