Hitachi capacity appear MB ( )
baldric
Postby baldric » 07.09.16, 12:29
Hi good afternoon,
Anybody like to try this issue?
My hitachi drive is not able to see the SA or userdata.
I can only the see
Model : HGST HTS725050A7E630
Serial : RC250ACB20239J
Firmware : GS2OA340
Capacity : MB ()
Selected family......................... : 7250A7
Model by ID............................. : HGST HTS725050A7E630
Techno mode key......................... : Error
ROM reading...
Possible Tech Key is found. Checking...
Error startintg command: Reading SA [0x3F0000004, 0x4]
Device error detected (ABR)
Error startintg command: Reading SA [0x3F0000004, 0x1]
Error reading module USAG(0): Error startintg command: Reading SA [0x3F0000004, 0x1]
Error startintg command: Reading SA [0x3F0100004, 0x4]
Error startintg command: Reading SA [0x3F0100004, 0x1]
Error reading module USAG(1): Error startintg command: Reading SA [0x3F0100004, 0x1]
Error : .............................................................. : Module USAG: no copies read!
Error : .............................................................. : Error executing loading "open" modules dir command
I did a head swap with a working donor drive.
The donor drive is still working, so the head in the patient drive before the head swap should be working.
Filipp_TS
Re: Hitachi capacity appear MB ( )
Postby Filipp_TS » 07.09.16, 16:38
As you can see drive can't to read USAG module from the Service area.
As result it can't to load list of SA modules.
Such behavior can be if drive have problem with Heads/surface or directly with both copies of USAG module in SA.
baldric
Postby baldric » 07.09.16, 18:35
Hi Filipp Good evening,
Thank you for your time explaining this.
Is there anyway i could get the data back out?
Hot-swap or replacing the PCB?
Postby DataMedics » 07.09.16, 22:44
baldric wrote:Source of the post Is there anyway i could get the data back out?
He already gave you the answer:
Filipp_TS wrote:Source of the post Such behavior can be if drive have problem with Heads/surface or directly with both copies of USAG module in SA
Most likely issue is heads.
baldric
Postby baldric » 08.09.16, 04:56
DataMedics wrote:Source of the post
Hi DataMedics,
thank you for writing,
I had the same error prior to doing head swap.
After the head swap, my donor drive is still working, and i can even read data from my donor drive.
so the head in the patient drive before the head swap should be working before the head replacement.
Postby DataMedics » 08.09.16, 14:56
Then the issue is the service area. If it can't load the list of modules, might just be stuck. I'm not sure if there's any way to force load a modules list in there. Maybe could try writing a donor modules list, but that's risky because if the modules are in different locations you could lose some critical modules after.
Possibly something along the lines of a hot swap from a very close donor with an attempt to read some critical modules would be the way to go, but you're venturing into pretty new territory there. Not sure it'd get much results.
baldric
Postby baldric » 17.09.16, 10:05
Thank you datamedic for the guide.
