Which adapter to use, TLGA-52?
Typical Flash recovery cases
oldman
Postby oldman » 20.08.16, 20:38
I have a NAND chip from a SKhynix,
H2JTFG8YD1BMS
BC A0 441A
Photo attached.
Which adapter to use?
TLGA-52?
Thanks.
Phil
Re: Which adapter to use, TLGA-52?
Postby Roman_TS » 22.08.16, 09:04
Hello!
This is TLGA-60 - it has 8 addition pins in central raw. You can try to read it with TLGA-52, but there might be issues.
Jaime
Postby Jaime » 12.03.18, 14:16
Hello Oldman,
I have the same problem,
I need to read the Nand chip H2JTFG8YD3MBR, this is too TLGA-60.
Could you to read the chip with apdapter TLGA-52?
Thank and regards.
Postby Roman_TS » 13.03.18, 11:13
For reading BGA-60 with TLGA-52 adapter, you have to chose reading scheme number 1785, and ignore all others during chip reading. It will help.
Postby Amarbir[CDR-Labs] » 23.03.18, 17:25
Roman_TS wrote:Source of the post For reading BGA-60 with TLGA-52 adapter, you have to chose reading scheme number 1785, and ignore all others during chip reading. It will help.
Well,
if i was at his place i will hardwire the chip to a monolith board :mrgreen:
Postby AJ2008 » 23.03.18, 17:29
I have never had success reading in TLGA-52 reader, but I only see this a small number of times so is not a problem to wire manually for reading
oldman
Postby oldman » 23.03.18, 18:11
Sorry for the delay as it is such old post, seem that I was not able to read and recover it successfully. :cry:
Jaime
Postby Jaime » 24.03.18, 09:49
I can not read it,
what is the pinout of the chip, to try to read the chip
