Hello there,
I am trying to retrieve the data from a Samsung SD card, this is its data:
Capacity: 8GB
Controller marking: MMB3R08GUACA-GE
Chip ID is detected as ECDED9CA
I make the dump, but then I am having the problem that it does not find ECC even after attempting XOR. I run XOR analysis and detects the mos suitable one as 252.
Have you analyzed similar memory?
Samsung SD card
Re: Samsung SD card
Hello. Please, follow to our TS portal and create a ticket. Our engineers will guide you with this case.
Re: Samsung SD card
Thanks for your reply, do I use the same login as the forum/blog? Or do I need to register for that site separately?
Nevermind, I was able to login now
