Hi Folks does anyone have this firmware: WD10EACS-00ZJB0 ROM 005C0032
or even just the 11.RPM loader will help a lot.
WD10EACS-00ZJB0 ROM 005C0032 Required
- odedshankar
Re: WD10EACS-00ZJB0 ROM 005C0032 Required
Im pretty sure these have internal ROM, cant you ROM build using a donor PCB?
Alternatively you can use donor PCB and LDR from the same donor to reach SA and make ROM manually from modules in SA
I think he's looking for the LDR, he was just pointing out the ROM version. The title threw me off too.
Anyway, here you go:
- Attachments
- 005C0032.rar
- (157.3 KiB) Downloaded 373 times
I talked with him at Skype and it was loader only he was looking for, hopefully he has managed to solve it now
- odedshankar
Thanks Guys, and thanks for the FW DATAMEDICS - appreciate your help. I chatted with Alyn through Skype and got the FW.
The problem was with corrupted loader, so all good, case is solved
