ST3320613AS- Data inaccessible afetr logical test
mscerl
Postby mscerl » 07.07.16, 13:06
Hi everyone,
I did a logical test on this seagate HDD and there were found a few bad sectors.
I moved them into the slip list. After that i did a new logical test but it cannot read the sectors from where the bad sectors were found to the last sector of the HDD !
is it possible to undo the changes?(the data is important)
thanks in advance for your help
Re: ST3320613AS- Data inaccessible afetr logical test
Postby AJ2008 » 07.07.16, 15:04
did you regen translator after adding defects?
lcoughey
Postby lcoughey » 07.07.16, 16:57
If the data is important, why were you testing the drive rather than imaging it? Only do what is necessary to get the drive to a condition that you can image quickly.
Postby DataMedics » 07.07.16, 22:51
lcoughey wrote:Source of the post If the data is important, why were you testing the drive rather than imaging it? Only do what is necessary to get the drive to a condition that you can image quickly.
Exactly what I was thinking. Why would you read all the sectors without saving them by doing a logical test? That feature is just for refurbishing/re-certifying drives, not data recovery.
mscerl
Postby mscerl » 08.07.16, 19:19
AJ2008 wrote:Source of the post did you regen translator after adding defects?
no i did not
mscerl
Postby mscerl » 08.07.16, 19:25
Because the owner didn't tell me.
lcoughey
Postby lcoughey » 08.07.16, 21:05
mscerl wrote:Source of the post
Here is a piece of advice. Never, ever, ever, ever, ever run a logical drive test on a drive that has data on it that you are not 100% sure is backed up or needed. Always, always, always make a clone first.
mscerl
Postby mscerl » 09.07.16, 20:58
Thanks for your advice
Postby Amarbir[CDR-Labs] » 14.07.16, 18:16
Well,
He Can Run if he wishes but he should not hide or play with defects
