st3250623a (not F3) cert error
it doesnt sound crashed, its softly retrying.
can I rewrite cert or?
here is terminal and log
Interface task reset
8192k x 16 buffer detected
TONKA - 1_Disk M-27 03-30-05 11:42
Spin Ready
3.04 09-29-05 16:27
(P)PATA Reset
Not Interface Age!
INVALID Cert Disk Code - ROM Resident Revision Required: 3.04
Command Inactive - No VALID Cert Code Detected
T>
T>
T>
T>Age=60 Type=00 MxCyl=00000 MxHd=0 MxSct=2DD BSz=4000 TCode=00000000
Tonka - 1_Disk 3.04 09-29-05 16:27
Built for Tonka,PITKIN,Redback,TI1810 PreAmp,Agere7531 PreAmp,InternalSpin,GC110,SVC127,OneToOne,3Disk,LowDelta,220 Servos,7200RPM,8Pole,NonModGray,100MHz,Code DRAM,Early Exit,Stall Converter,RwFeat=0000,SeaDex,VBAR,MDW
T>INVALID Cert Disk Code - ROM Resident Revision Required: 3.04
T>r1
T>60 Type=00 MxCyl=00000 MxHd=0 MxSct=2DD BSz=4000 TCode=00000000
cmd 3E, params FFFF 0072 0000 0094 0008 0010 0000 0000 0000 0000 0000
T>P
============ LOG ===============================
Test : HDD initialization with head map changing in RAM
Initializing Safe Mode...
Switching HDD power supply OFF
Switching HDD power supply ON
COM transfer baud rate set to 921000
Test : Saving LDR from HDD
HDD profile file......... : C:\Program Files\PC3K\Bin\!Profiles\SeagateBara\Barracuda 7200.8 Tonka\ST3250623A-3-04-5nd1lrfr_sc4924\Data\HDDInit\SgLDR_App.ldr
Will be stored........... : App
App code reading...
HDD SpinUp.............................. : Ok
Reading boot SA elements...
Detecting App code parameters...
Detecting App code parameters........... : Ok
App cylinder............................ : 0x163E8
App length.............................. : 0x1A0
App buffer.............................. : 0x60
Terminal : detecting SA bounds...
Detection of SA bounds by MUX
SA bounds identified
App code reading........................ : Ok
ROM image reading...
Test : HDD initialization by utility...
Switch HDD PWR supply.... : No
Terminal Reset........... : No
Terminal work speed...... : 921000
Used LDR................. : C:\Program Files\PC3K\Bin\!Profiles\SeagateBara\Barracuda 7200.8 Tonka\ST3250623A-3-04-5nd1lrfr_sc4924\Data\HDDInit\SgLDR_App.ldr
Loaded from.............. : C:\Program Files\PC3K\Bin\!Profiles\SeagateBara\Barracuda 7200.8 Tonka\ST3250623A-3-04-5nd1lrfr_sc4924\Data\HDDInit\SgLDR_Utl.ldr
Work with HDD through.... : ATA
App...................... : Loading from LDR
Used modifications....... : Fix 'Not Handled Soft Path' Bug, Fix 'Failed sys sect. write', Allow ATA LBA->PCHS conversion, Block saving Alt-list, Block saving System Sectors, Block saving mem buffer to surface, Head Map correction
Load Ovl 0............... : No
Loading App Loader...
App patching...
Downloading App code...
App code downloading.................... : Ok
Reading boot adaptives.................. : Ok
Reading Reserve track defect list....... : Ok
Starting App code...
3.04 09-29-05 16:27
cmd 2A, params 0000 0072 0000 0094 0008 0000 0000 0000 0000 0000 0000
(P)PATA Reset
Not Interface Age!
cmd 58, params 0032
Drive is not ready
Starting App code....................... : Ok
Cannot start App!
Cannot start App!
Cannot start App!
Executing user command.................. : Show PCB information
Terminal : error switching to "F>" level
Executing user command.................. : Show ROM information
HDD profile file......... : C:\Program Files\PC3K\Bin\!Profiles\SeagateBara\Barracuda 7200.8 Tonka\ST3250623A-3-04-5nd1lrfr_sc4924\Data\LDR\SgLDR.ldr
Will be stored........... : ROM, App, CERT code, CERT tables, Ovl 0, Stuff, DRV cfg
DRV cfg reading...
DRV cfg reading......................... : Ok
STUFF reading...
Detecting Stuff position...
Stuff cylinder.......................... : 0x1643E
Vendor Data start....................... : 0x14
PN...................................... :
STUFF reading........................... : Ok
CERT code reading...
Trying to load CERT
CERT code reading....................... : Error
Error loading CERT code
Will be stored........... : ROM, App, CERT tables, Ovl 0, Stuff, DRV cfg
DRV cfg reading...
STUFF reading...
CERT tables reading...
Trying to load CERT
CERT tables reading..................... : Error
terminal
