Need Modules for MHY2160BH
Athena
Postby Athena » 25.06.16, 12:42
Dear Friends
This disk is showing typical error of P list corruption. Is someone having modules for this model ?
Thank you
Re: Need Modules for MHY2160BH
Postby Amarbir[CDR-Labs] » 26.06.16, 10:14
Athena wrote:Source of the post Dear Friends
Thank you
Well,
plist is unique to every hard drive its not replaceable from other donors
Athena
Postby Athena » 26.06.16, 10:33
Amarbir[CDR-Labs] wrote:Source of the post
Thank you
Well,
HI Amarbirji
Thanks for replying.I mean actual P list is not corrupt. Its like this --
even if some modules are corrupt , zone allocation reading fails so its not actual P list corruption.
These are A or B modules if they are repaired sector access becomes normal.I can read P list perfectly .
Here is log --
elected family......................... : MHW2xxxBH
Selected model.......................... : MHWxxxxBH
Model by HDD ID......................... : FUJITSU MHW2160BH PL
Firewall state: 0
Unlocking...
Firewall state: 2
Tech command set: SATA cmd set
Reading module table from SA...
Module table is loaded
Loading : HS, head map module......................................... : Ok
Loading : PL, single sector defect list and zone allocation table module : Error
Error................................................................. : PL: Invalid zones distribution info (ZoneNo)!
LOADING MODULES
Module 10004.......................................................... : Ok
Module 10020.......................................................... : Ok
Module 10006.......................................................... : Ok
Module 10022.......................................................... : Ok
Module 100E1.......................................................... : Ok
Can`t read module 1003D from HDD
Module 1003D.......................................................... : Error
Can`t read module 1003E from HDD
Module 1003E.......................................................... : Error
Can`t read module 1003F from HDD
Module 1003F.......................................................... : Error
Can`t read module 10040 from HDD
Module 10040.......................................................... : Error
Can`t read module 1005A from HDD
Module 1005A.......................................................... : Error
Can`t read module 1005B from HDD
Module 1005B.......................................................... : Error
Module 10001.......................................................... : Ok
Can`t read module 100E8 from HDD
Module 100E8.......................................................... : Error
Module 10007.......................................................... : Ok
Module 100E2.......................................................... : Ok
Module 10008.......................................................... : Ok
Can`t read module 1000C from HDD
Module 1000C.......................................................... : Error
Can`t read module 1000D from HDD
Module 1000D.......................................................... : Error
Module 1000A.......................................................... : Ok
Module 1002D.......................................................... : Ok
Module 1002B.......................................................... : Ok
Module 1002A.......................................................... : Ok
Module 10009.......................................................... : Ok
Module 10031.......................................................... : Ok
Module 10027.......................................................... : Ok
Module 10032.......................................................... : Ok
Module 10028.......................................................... : Ok
Module 10045.......................................................... : Ok
Module 10070.......................................................... : Ok
Module 10029.......................................................... : Ok
Module 10037.......................................................... : Ok
Module 100E9.......................................................... : Ok
Module 100EA.......................................................... : Ok
Can`t read module 100ED from HDD
Module 100ED.......................................................... : Error
Module 1006C.......................................................... : Ok
Can`t read module 10050 from HDD
Module 10050.......................................................... : Error
Can`t read module 10055 from HDD
Module 10055.......................................................... : Error
Can`t read module 10054 from HDD
Module 10054.......................................................... : Error
Module 10051.......................................................... : Ok
Module 10052.......................................................... : Ok
Can`t read module 10057 from HDD
Module 10057.......................................................... : Error
Can`t read module 10058 from HDD
Module 10058.......................................................... : Error
Module 10002.......................................................... : Ok
Module 1000B.......................................................... : Ok
Module 10005.......................................................... : Ok
Module 1000E.......................................................... : Ok
Module 10030.......................................................... : Ok
Module 10035.......................................................... : Ok
Module 10036.......................................................... : Ok
Module 1002E.......................................................... : Ok
Module 10041.......................................................... : Ok
Module 10042.......................................................... : Ok
Module 100A0.......................................................... : Ok
Module 10003.......................................................... : Ok
Module 100E3.......................................................... : Ok
Module 100A9.......................................................... : Ok
Module 100AA.......................................................... : Ok
Module 100AB.......................................................... : Ok
Module 100AC.......................................................... : Ok
Module 100AD.......................................................... : Ok
Module 10023.......................................................... :
Postby Amarbir[CDR-Labs] » 26.06.16, 15:36
Thank you
Well,
HI Amarbirji
Here is log --
Firewall state: 0
Unlocking...
Firewall state: 2
LOADING MODULES
Well Cannot Say anything to this statement you Made .I Am Not To Well Versed With Fujitsu Drives ,But i am Of the Opinion PC 3k Makes a Lot Of Errors in SA even in a OK Drive Wonder Why ,Try it With Some Other Tools also
Athena
Postby Athena » 27.06.16, 11:08
Hi Fillip & Pavel .. TS team
PM sent are not getting delivered & are laying in outbox only.
Kindly look into the matter as it is causing great inconvinience.
Thank you
Filipp_TS
Postby Filipp_TS » 02.09.16, 10:48
Hi all
Amarbir[CDR-Labs] wrote:Source of the post plist is unique to every hard drive its not replaceable from other donors
Yes, correct.
Athena wrote:Source of the post Loading : PL, single sector defect list and zone allocation table module : Error
This message mean not an error of P-list.
It mean that drive have a special format of P-list and it can't be recognazable by utility.
Return to “Fujitsu”
