Bad/blown ROM chip on HTS545050B9A300 drive...
300ddr
Postby 300ddr » 23.06.16, 19:38
...and we can't find a donor PCB with the same ROM version (C60F). We have many C64 and some C60Q, but no C60F. Does anyone know of a method to "trick" the drive into using a different version ROM? Or, does anyone happen to have a PCB (0A71398 DA2969) with C60F they'd be willing to sell or lend (for a fee)?
Thanks,
Brian
Re: Bad/blown ROM chip on HTS545050B9A300 drive...
Postby AJ2008 » 24.06.16, 15:38
Hi Brian,
I have 5 resources in my Database with this ROM version, not sure if either will be ok so i exported them all:
https://www.dropbox.com/s/lagr72g0tqmv0 ... s.pcr?dl=0
Hopefully this will be enough :)
Postby Amarbir[CDR-Labs] » 24.06.16, 15:55
300ddr wrote:Source of the post ...and we can't find a donor PCB with the same ROM version (C60F). We have many C64 and some C60Q, but no C60F. Does anyone know of a method to "trick" the drive into using a different version ROM? Or, does anyone happen to have a PCB (0A71398 DA2969) with C60F they'd be willing to sell or lend (for a fee)?
Thanks,
Brian
Brian ,
Brother Assuming You Get a ROM Of Same firmware No ,As Far As i Know NVRAM Section is also in this rom " How Will You Adapt This To Your Patient Due To Unique Adaptive " .Might Bwe You Could Read Native ROM/NVRAM as i am not clear on this
