4 GB transcend USB drive is identified as 8 GB.
Imnew
Postby Imnew » 19.05.16, 14:00
Hello, I am new to PC 3000 Flash.
I have 4gb Transcend drive. I have taken out the memory chip and mounted in PC 3000 Flash.
When Read chip ID, it is identified as 8 GB.
What should I do. Can ACE help ??
Re: 4 GB transcend USB drive is identified as 8 GB.
Postby Roman_TS » 19.05.16, 16:17
Hello. If you bought PC-3000 Flash from our reseller in India - you should speak with Vikas about technical support assistance.
Imnew
Postby Imnew » 20.05.16, 19:21
I had bought directly from you more than a year back. Hardly got cases for data recovery from USB as such such dont have much exposure to PC 3000 Flash.
Its a Ace Forum and hence expect some help.
I shall appreciate if I get a response.
Postby Roman_TS » 20.05.16, 21:53
Please, contact with our technical support department on ts.acelab.eu.com
We will check your product serial number, and if it's correct, we would be pleased to help you.
Postby Roman_TS » 14.06.16, 10:51
Test message :)
Maxim_TS
Postby Maxim_TS » 14.06.16, 10:55
message test
Postby Amarbir[CDR-Labs] » 14.06.16, 18:24
Roman_TS wrote:Source of the post Hello. If you bought PC-3000 Flash from our reseller in India - you should speak with Vikas about technical support assistance.
Well,
I Have a Strong ,Infact Extremely Strong Statement against This ,But i Have Kept My Hand And Mind Under Control Since Many Months .But i Will Not Talk About This Publicly .@ Imnew : What Version Do You Have In PC3k Flash
