Donor PCB matching for MQ01ABB200
Imnew
Postby Imnew » 13.05.16, 09:36
Hi all. I have the mentioned HDD. PCB is bad. What should I match in the Donor PCB. Thanks
pclab
Re: Donor PCB matching for MQ01ABB200
Postby pclab » 16.05.16, 14:39
What's the PCB model?
Postby AJ2008 » 09.06.16, 11:23
Match spindle controller and RAM chip from SATA equivalent PCB
Postby Amarbir[CDR-Labs] » 14.06.16, 18:27
Imnew wrote:Source of the post Hi all. I have the mentioned HDD. PCB is bad. What should I match in the Donor PCB. Thanks
Brother ,
Is This a USB PCB ,Sorry i did not check the same on google ,But if it is you need to match mcu and motor controller and nothing to do with Ram chip in my humble opinion
Postby AJ2008 » 27.06.16, 10:11
ABB - SATA, I guess model match alone with ROM transfer would be ok, but pay attention to RAM and MCU as they can vary between PCBs
Return to “Toshiba native”
