Having trouble with Data Extractor
jeyk
Postby jeyk » 14.04.16, 21:29
I am having trouble making new tasks in my DE. This is the error:
Error: CreateTask - TTask.Create - Error: TTask.Create - CreateDrive - Cannot perform operation --DB is not open.
I don't want to reinstall the software unless I absolutely have to, I'm hoping someone has a good fix for me.
Re: Having trouble with Data Extractor
Postby Amarbir[CDR-Labs] » 18.04.16, 17:44
jeyk wrote:Source of the post I am having trouble making new tasks in my DE. This is the error:
I do Not Know Much About this Specific Issue But Is the Path Of Creating Cases All Setup Right ?
jeyk
Postby jeyk » 19.04.16, 01:48
Amarbir[CDR-Labs] wrote:Source of the post
It should be. Is there any way I can check? I think what might have happened was some files got moved from the /bin folder.
LoboXus
Postby LoboXus » 10.05.16, 04:11
Have the same problem, weird.
jskramer
Postby jskramer » 16.06.16, 06:14
I am now having this problem. Why was there never an answer posted? Is it because no one found one?
jeyk
Postby jeyk » 23.06.16, 00:00
I know, right?
ThomasH
Postby ThomasH » 08.07.16, 05:17
I have had this or something like this occur a couple times. (I'm not sure it's exactly the same though). A complete power down of the computer and restart fixed both times.
Nick_TS
Postby Nick_TS » 20.07.16, 22:25
In these cases, try to close the utility and shut down amd power on computer.
Else try to re-install software.
adrianf25
Postby adrianf25 » 14.05.24, 02:07
The problem is how the task was created without saving sectors and then it was not connected.
Error TTask.Create - CreateDrive - Drive source not found.png (32.17 KiB) Viewed 13344 times
Return to “Data Extractor”
