Hello guys. Quick question. Which utility I can use to start this drive?
Best Regards
Adam
Toshiba MQ01UBF050
Re: Toshiba MQ01UBF050
Have you adapted it to SATA? I don't think PC-3000 can work with USB Toshiba at all.
After you switch the PCB to SATA you should be able to work with it using the MQ01ABD utility.
- eisltd_adam
Thank you
- eisltd_adam
Thank you
Hi ,
How did The Case Go ?.Can you Shed Some Light
Hi to all.
What exactly is not clean regarding this case?
Also, new software version 6.1.12 is support Toshiba drives connected thru USB connection
