Creating a loader from saved resources
I need to create a loader from a previously saved set of resources from a good drive of the same FW version as my bad drive. Is there a method to do this?
Re: Creating a loader from saved resources
If you know the loader version, you can get it from another drive.
pclab wrote:Source of the post If you know the loader version, you can get it from another drive.
Hi PCLAb,
Still Not Understood when you Folks apply Loader In F3 Family ,When and why Is My Answer .
Hi Msurgeon,
Loader is a File Combining Many file ,Create a New Loader of Same Family and Find Out which File is Stored At What offsets and then combine your older saved resources in winhex to make a loader .Frank zabkar From Australia Had dissected Lod Files At Some Forums Sometime Back .
Thanks, Amarbir. I remember reading the posts on hddguru about this but it was hardly a simple matter to put the pieces together manually. I would have thought that this would have been a desirable feature in the F3 utility. Perhaps in some future upgrade.
Hello msurgeon and Amarbir,
Loader is used when the drive comes to ready state but you can't send any terminal command due to damaged diagnostic overlay. A loader applies the diag ovellay in RAM via ATA command.
For detailed procedure you can read video:
https://www.youtube.com/watch?v=l6XZ_mIlZSY
You have to save system file (100 - 105). If you have these system files then contact our TS department (ts.acelab.eu.com) we will create you loader from these files.
Amarbir[CDR-Labs] wrote:Source of the post Still Not Understood when you Folks apply Loader In F3 Family ,When and why Is My Answer .
msurgeon wrote:Source of the post I need to create a loader from a previously saved set of resources from a good drive of the same FW version as my bad drive. Is there a method to do this?
Dmitriy_TS wrote:Source of the post Hello msurgeon and Amarbir,Amarbir[CDR-Labs] wrote:Source of the post Still Not Understood when you Folks apply Loader In F3 Family ,When and why Is My Answer .
https://www.youtube.com/watch?v=l6XZ_mIlZSYmsurgeon wrote:Source of the post I need to create a loader from a previously saved set of resources from a good drive of the same FW version as my bad drive. Is there a method to do this?
Hi Dimitry Sir ,
Got It Loud And Clear Will Remember Next Time
