Your And Mine Wishlist - For Blog Of Acelab
Postby Amarbir[CDR-Labs] » 31.03.16, 19:07
Hello Team Ace ,
First of All A Thumbs Up For Bringing And Introducing Blog .Now This Seems Useless -> http://ts.acelab.eu.com/index.php?/ ... ebase/List .I Am Seeing That You Folks Are Adding Blog Enteries From The Old TS Knowledge base To New Blog " My Suggestion Is That You Remove All Knowledgebase Enteries From There And Add Real Customer Case Studies There ,It Would Be So Interesting And Keep The Blog Rolling With PC3K Techniques ." . I Have My Wishlist For Blog Enteries And I Would Like Other Members Also To Joing This Post Of Mine And Pour Their Hear Out To The Ace Team With Their Wishlist ,Mine Is
1 : Hitachi NVram Solution And Virtual Translator
2 : How Seagate Firmware Works Completely [ Like What is User Area,System Area ,Modules And System File ,Specially Rom ]
3 : Cleaning Heads And Platters [ Please Please Some Real Recommendations ]
4 : Some SCSI/SAS Blogs [ Please Absolutely No Discussion On This is Happening ]
Re: Your And Mine Wishlist - For Blog Of Acelab
Postby Roman_TS » 01.04.16, 09:27
Hello Amarbir!
Thank you for your feedback and for your wish list - of course we all are interesting in adding the most required articles in our blog. We will try to write all this material in nearest time.
It's a good idea to tell us which articles will be interesting for our customers.
Postby Amarbir[CDR-Labs] » 01.04.16, 10:54
Roman_TS wrote:Source of the post Hello Amarbir!
If We Have the Capability To Create your Blog Like Forum Posts Can You Consider then Adding to Blog Also " If Indeed You Find Them Interesting " .Like This you could Have Some Interesting User contribution Also .
Postby Amarbir[CDR-Labs] » 22.02.17, 18:39
Roman ,
Please Find New Wish List From My Side That I Would Like To See in The Blog
PC 3000 Flash Section
1 : How To Solder BGA Type NAND Into Your Adapters As They Have Through Hole Topology.
2 : Real Life Case Examples Of Cases i Can Add Mine To This Forum And Might Be You Folks Can Add a Few There
3 : How To Add Solved cases to Global Solution Center properly with pics etc .I added one solution and its all in the wrong place
4 : How To select proper id when chip gives two id's basic and extended
Seagate
1 : A Flowchart how the seagate drives initialise firmware from start to end
Western Digital
1 : Moving Complete SA To Different Head [ When SA Has Bad Sectors And We Have Read SA Using Composite Mode
Postby Amarbir[CDR-Labs] » 31.10.17, 17:02
Hello Team TS ,
I want you to add a few Flash Articles to Blog in Which You Explain Step By Step What You did And Why .Simple ,Intermediate And Complex Controllers
Return to “Discussion club”
