Two reported number in DE..... what are they? Topic is solved
osity
Postby osity » 22.03.16, 01:16
In data extractor, under the status tab... its displays 2 transfers speeds. i.e: 734kb/19.6MB/s
Why does is list two numbers? If the second number is the transfer speed whats the first number?
Re: Two reported number in DE..... what are they?
Postby Amarbir[CDR-Labs] » 22.03.16, 02:47
Well,
According To Me First One Is Source And Second One Is Destination
osity
Postby osity » 22.03.16, 05:05
Hi Amarbir....
That doesn't sound useful. I don't think that's what it is . If I had to guess I would guess the two are current file imaging progress, and total transfer speed. But I would like confirmation if anyone else Knows. Thanks
Postby Amarbir[CDR-Labs] » 22.03.16, 11:12
osity wrote:Source of the post Hi Amarbir....
Sir ,
What i mean is transfer speed of source and destination
osity
Postby osity » 22.03.16, 15:47
Why would you think the source and destination transfers speeds would be different? That wouldn't work because they have to sych with each other for it to work at all.
Postby Amarbir[CDR-Labs] » 22.03.16, 17:19
osity wrote:Source of the post Why would you think the source and destination transfers speeds would be different? That wouldn't work because they have to sych with each other for it to work at all.
Well,
You Can ASk Tech Support i am 100% Positive i Have Correctly Nailed This
300ddr
Re: Two reported number in DE..... what are they?  Topic is solved
Postby 300ddr » 23.03.16, 20:48
I think it's current speed and average speed.
Postby DataMedics » 24.03.16, 18:30
Amarbir[CDR-Labs] wrote:Source of the postYou Can ASk Tech Support i am 100% Positive i Have Correctly Nailed This
I guess that makes you 100% wrong :D . 300DDR is correct, it's current speed / average speed. That's why the first number changes every two seconds, but the latter one is more gradual.
osity
Postby osity » 24.03.16, 20:47
Thanks for the info guys!!
Current speed and average speed makes sense.
There was nothing about it in the manual.
Postby Amarbir[CDR-Labs] » 25.03.16, 06:47
DataMedics wrote:Source of the post
Hi ,
The Info Is Like This
1 : Some Number(Some number)/Some Number
So is we talk about some number/some number i am correct ,But if you talk about some number(some number)/some number the (some number ) is average speed when its reading .I was not wrong .
osity
Postby osity » 25.03.16, 17:33
Amarbir. Please stop. :roll: It's silly at this point.
Postby Amarbir[CDR-Labs] » 25.03.16, 18:35
osity wrote:Source of the post Amarbir. Please stop. :roll: It's silly at this point.
Well,
The Question is Confusing To Began With " Atleast For Me " .Under the Status Tab the Following Are the Sub Parameters
Process , Parameter , Value ,Percentage % , Speed ,Time ,started And finished
Now You Just Said " In data extractor, under the status tab... its displays 2 transfers speeds. i.e: 734kb/19.6MB/s " .this Means you are reffering to 6th parameter in status tab .I Kept On Flipping My Mind From Value Parameter Tab To Speed .Then i Took a Deep Breath and Again Saw The Tabs And i Think The Speed Parameter Tab Indeed In Current Speed/Average Speed [ But i Would Like Ace To Give a Final Reply ] ,Sorry Bro :(
Nick_TS
Postby Nick_TS » 04.04.16, 20:25
300ddr wrote:Source of the post I think it's current speed and average speed.
You are right, this is currect and average rate.
Return to “Data Extractor”
