Undetected Hitachi HDS721616PLA320 "Open Module Error"
Postby Amarbir[CDR-Labs] » 10.03.16, 21:18
Hello TS Team ,
I Have This Drive Since Many Months .Long Before I Had PC3K also Using Other Tool .I Though Its a NVRAM Issue And i Borrowed a Matching NVRAM Adapted It And Got SA Access .I Was Able To Read NVRC Module Then .I Wrote This NVRC Module to NVRAM And Now This Is What i Get Still No Access To User Data
When i Start i Have To Manually Select " HDx7216PL "
Loading data for correction of HDD family handling settings from section MEM_P
Selected family......................... : HDx7216PL
Model by ID............................. :
NV-RAM reading.......................... : Ok
WARNING! The HDD may be in limited SA access mode at the moment!
Loading modules table................................................. : Ok
Error : .............................................................. : Error executing loading "open" modules dir command
Loading zone allocation table......................................... : Ok
Structure Testing Is As Under "Please Help Me Solve This Issue "
ROM ID.................................. : AB0A
NV-RAM ID............................... : P2COEB9Á
USAG version ........................... : P2C6EBGA
NV-RAM parameters
NV-RAM report
Checksum................................ : Ok
ID...................................... : E2PR
mu-code................................. : P2COEB9Á
FW Ver Code............................. : 0x12ECFD0E
Heads................................... : 2
Head map................................ : 1 0 7 7 7 7
Module copy ABA modifier for SA......... : 0x1000
Base for cyl defect list................ : 0x1DC9E
SA top cyl delimiter.................... : 0x14EB2
Used module table
Report on module USAG, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
mu-code................................. : P2C6EBGA
FW Ver code............................. : 12ECFD0E
Incompatible with NV-RAM!
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : :(original): (sect): (sect): (byte) : RAM : : :
RSVD : 0 : B : 7FD20000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : 1 : B : 7FD21000 : 7FD20000 : 4 : 4 : 2048 : 00000000 : Yes : Ok : SA marker
RSVD : F : B : 7FD60000 : 7FD20000 : 4 : 0 : 2048 : 00000000 : No : : SA marker
USAG : 0 : B : 7FE20000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : 1 : B : 7FE21000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
USAG : F : B : 7FE60000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
PSHT : 0 : Ad : 7FE40000 : 7FE40000 : 230 : 230 : 0 : 00004000 : Yes : Ok : P-List module
PSHT : 1 : Ad : 7FE41000 : 7FE40000 : 230 : 230 : 0 : 00004000 : Yes : Ok : P-List module
PSHT : F : Ad : 7FE61000 : 7FE40000 : 230 : 230 : 0 : 00004000 : Yes : Ok : P-List module
RDMT : 0 : Ad : 7FE400E6 : 7FE400E6 : 32 : 32 : 16384 : 00020C00 : Yes : Ok : G-List module
RDMT : 1 : Ad : 7FE410E6 : 7FE400E6 : 32 : 32 : 16384 : 00020C00 : Yes : Ok : G-List module
RDMT : F : Ad : 7FE610E6 : 7FE400E6 : 32 : 32 : 16384 : 00020C00 : Yes : Ok : G-List module
RLBA : 0 : B : 7FE200E9 : 7FE200E9 : 1 : 1 : 80 : 00030380 : Yes : Ok : G-List reserves table module
RLBA : 1 : B : 7FE210E9 : 7FE200E9 : 1 : 1 : 80 : 00030380 : Yes : Ok : G-List reserves table module
RLBA : F : B : 7FE600E9 : 7FE200E9 : 1 : 1 : 80 : 00030380 : Yes : Ok : G-List reserves table module
CNSL : 0 : B : 7FE200CF : 7FE200CF : 1 : 1 : 480 : 0003C700 : Yes : Ok : HDD logical configuration module
CNSL : 1 : B : 7FE210CF : 7FE200CF : 1 : 1 : 480 : 0003C700 : Yes : Ok : HDD logical configuration module
CNSL : F : B : 7FE600CF : 7FE200CF : 1 : 1 : 480 : 0003C700 : Yes : Ok : HDD logical configuration module
RWCN : 0 : B : 7FE200D0 : 7FE200D0 : 1 : 1 : 114 : 0003CED8 : Yes : Ok :
RWCN : 1 : B : 7FE210D0 : 7FE200D0 : 1 : 1 : 114 : 0003CED8 : Yes : Ok :
RWCN : F : B : 7FE600D0 : 7FE200D0 : 1 : 1 : 114 : 0003CED8 : Yes : Ok :
CHNM : 0 : Ad : 7FE200FA : 7FE200FA : 36 : 36 : 16864 : 00034000 : Yes : Ok :
CHNM : 1 : Ad : 7FE210FA : 7FE200FA : 36 : 36 : 16864 : 00034000 : Yes : Ok :
CHNM : F : Ad : 7FE600FA : 7FE200FA : 36 : 36 : 16864 : 00034000 : Yes : Ok :
SRVP : 0 : B : 7FE200D3 : 7FE200D3 : 2 : 2 : 624 : 00038800 : Yes : Ok :
SRVP : 1 : B : 7FE210D3 : 7FE200D3 : 2 : 2 : 624 : 00038800 : Yes : Ok :
SRVP : F : B : 7FE600D3 : 7FE200D3 : 2 : 2 : 624 : 00038800 : Yes : Ok :
SRVM : 0 : Ad : 7FE200EA : 7FE200EA : 16 : 16 : 8054 : 00038C00 : Yes : Ok : Module contains cylinder defects table
SRVM : 1 : Ad : 7FE210EA : 7FE200EA : 16 : 16 : 8054 : 00038C00 : Yes : Ok : Module contains cylinder defects table
SRVM : F : Ad : 7FE600EA : 7FE200EA : 16 : 16 : 8054 : 00038C00 : Yes : Ok : Module contains cylinder defects table
ZONE : 0 : Ad : 7FE200E1 : 7FE200E1 : 3 : 3 : 1421 : 0003BD00 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 7FE210E1 : 7FE200E1 : 3 : 3 : 1421 : 0003BD00 : Yes : Ok : Zone allocation table module
ZONE : F : Ad : 7FE600E1 : 7FE200E1 : 3 : 3 : 1421 : 0003BD00 : Yes : Ok : Zone allocation table module
PTRT : 0 : B : 7FE200E8 : 7FE200E8 : 1 : 1 : 480 : 0002E2B0 : Yes : Ok :
PTRT : 1 : B : 7FE210E8 : 7FE200E8 : 1 : 1 : 480 : 0002E2B0 : Yes : Ok :
PTRT : F : B : 7FE600E8 : 7FE200E8 : 1 : 1 : 480 : 0002E2B0 : Yes : Ok :
RAM0 : 0 : B : 7FE20002 : 7FE20002 : 101 : 101 : 51712 : 00050000 : Yes : Ok : Code module
RAM0 : 1 : B : 7FE21002 : 7FE20002 : 101 : 101 : 51712 : 00050000 : Yes : Ok : Code module
RAM0 : F : B : 7FE60002 : 7FE20002 : 101 : 101 : 51712 : 00050000 : Yes : Ok : Code module
OVR1 : 0 : B : 7FE20067 : 7FE20067 : 100 : 100 : 10240 : 0005CA00 : Yes : Ok : Code overlay module
OVR1 : 1 : B : 7FE21067 : 7FE20067 : 100 : 100 : 10240 : 0005CA00 : Yes : Ok : Code overlay module
OVR1 : F : B : 7FE60067 : 7FE20067 : 100 : 100 : 10240 : 0005CA00 : Yes : Ok : Code overlay module
SMRT : 0 : B : 7FE200D8 : 7FE200D8 : 1 : 1 : 512 : 0003BB00 : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210D8 : 7FE200D8 : 1 : 1 : 512 : 0003BB00 : Yes : Ok : S.M.A.R.T. module
SMRT : F : B : 7FE600D8 : 7FE200D8 : 1 : 1 : 512 : 0003BB00 : Yes : Ok : S.M.A.R.T. module
MLBA : 0 : B : 7FE200D9 : 7FE200D9 : 1 : 1 : 302 : 0003C900 : Yes : Ok : HDD logical configuration module
MLBA : 1 : B : 7FE210D9 : 7FE200D9 : 1 : 1 : 302 : 0003C900 : Yes : Ok : HDD logical configuration module
MLBA : F : B : 7FE600D9 : 7FE200D9 : 1 : 1 : 302 : 0003C900 : Yes : Ok : HDD logical configuration module
SECI : 0 : B : 7FE200DA : 7FE200DA : 1 : 1 : 74 : 00030330 : Yes : Ok : Security information module
SECI : 1 : B : 7FE210DA : 7FE200DA : 1 : 1 : 74 : 00030330 : Yes : Ok : Security information module
SECI : F : B : 7FE600DA : 7FE200DA : 1 : 1 : 74 : 00030330 : Yes : Ok : Security information module
SRIF : 0 : B : 7FE200D5 : 7FE200D5 : 1 : 1 : 2 : 0003D2DA : Yes : Ok : Self Test start management module
SRIF : 1 : B : 7FE210D5 : 7FE200D5 : 1 : 1 : 2 : 0003D2DA : Yes : Ok : Self Test start management module
SRIF : F : B : 7FE600D5 : 7FE200D5 : 1 : 1 : 2 : 0003D2DA : Yes : Ok : Self Test start management module
SERL : 0 : B : 7FE200DC : 7FE200DC : 3 : 3 : 1536 : 00033600 : Yes : Ok : S.M.A.R.T. error log module
SERL : 1 : B : 7FE210DC : 7FE200DC : 3 : 3 : 1536 : 00033600 : Yes : Ok : S.M.A.R.T. error log module
SERL : F : B : 7FE600DC : 7FE200DC : 3 : 3 : 1536 : 00033600 : Yes : Ok : S.M.A.R.T. error log module
IDNT : 0 : B : 7FE200D1 : 7FE200D1 : 2 : 2 : 560 : 0002E4D0 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 7FE210D1 : 7FE200D1 : 2 : 2 : 560 : 0002E4D0 : Yes : Ok : HDD ID data module
IDNT : F : B : 7FE600D1 : 7FE200D1 : 2 : 2 : 560 : 0002E4D0 : Yes : Ok : HDD ID data module
DCOT : 0 : B : 7FE200DB : 7FE200DB : 1 : 1 : 12 : 0003CB00 : Yes : Ok :
DCOT : 1 : B : 7FE210DB : 7FE200DB : 1 : 1 : 12 : 0003CB00 : Yes : Ok :
DCOT : F : B : 7FE600DB : 7FE200DB : 1 : 1 : 12 : 0003CB00 : Yes : Ok :
PTCH : 0 : B : 7FE200CB : 7FE200CB : 3 : 3 : 1269 : 0005F200 : Yes : Ok : Microcode connections table module
PTCH : 1 : B : 7FE210CB : 7FE200CB : 3 : 3 : 1269 : 0005F200 : Yes : Ok : Microcode connections table module
PTCH : F : B : 7FE600CB : 7FE200CB : 3 : 3 : 1269 : 0005F200 : Yes : Ok : Microcode connections table module
##01 : 0 : : 7FE200CE : 7FE200CE : 1 : 1 : 512 : 00000000 : Yes : Skip : Main SA track hole
##01 : 1 : : 7FE210CE : 7FE200CE : 1 : 1 : 512 : 00000000 : Yes : Skip : Main SA track hole
##01 : F : : 7FE600CE : 7FE200CE : 1 : 1 : 512 : 00000000 : Yes : Skip : Main SA track hole
##02 : 0 : : 7FE200D6 : 7FE200D6 : 2 : 2 : 1024 : 00000000 : Yes : Skip : Main SA track hole
##02 : 1 : : 7FE210D6 : 7FE200D6 : 2 : 2 : 1024 : 00000000 : Yes : Skip : Main SA track hole
##02 : F : : 7FE600D6 : 7FE200D6 : 2 : 2 : 1024 : 00000000 : Yes : Skip : Main SA track hole
##03 : 0 : : 7FE200DF : 7FE200DF : 2 : 2 : 1024 : 00000000 : Yes : Skip : Main SA track hole
##03 : 1 : : 7FE210DF : 7FE200DF : 2 : 2 : 1024 : 00000000 : Yes : Skip : Main SA track hole
##03 : F : : 7FE600DF : 7FE200DF : 2 : 2 : 1024 : 00000000 : Yes : Skip : Main SA track hole
##04 : 0 : : 7FE200E4 : 7FE200E4 : 4 : 4 : 2048 : 00000000 : Yes : Skip : Main SA track hole
##04 : 1 : : 7FE210E4 : 7FE200E4 : 4 : 4 : 2048 : 00000000 : Yes : Skip : Main SA track hole
##04 : F : : 7FE600E4 : 7FE200E4 : 4 : 4 : 2048 : 00000000 : Yes : Skip : Main SA track hole
PESD : : D : 7FE90000 : 7FE90000 : 128 : 128 : 65536 : 00000000 : Yes : Error : PES data log
SRST : : C : 7FEB0000 : 7FEB0000 : 255 : 218 : 130560 : 00000000 : No : : Self Test report module
SSSC : : Dr : 7FEA0009 : 7FEA0009 : 5 : 5 : 2560 : 00000000 : Yes : Skip : Self Test management and status module
SSCD : : Dr : 7FEA0018 : 7FEA0018 : 81 : 81 : 41472 : 00000000 : Yes : Skip : Self Test code module
NVRC : : Dd : 7FEA01FE : 7FEA01FE : 2 : 2 : 1024 : 00000000 : Yes : Ok : NV-RAM image module
Modules checking completed
Information about copy 0
Report on module RSVD, "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 4
Report on module RAM0, "Code module"
ABA..................................... : 7FE20002
Length (sectors)........................ : 101
mu-code................................. : ABGA
Incompatible with active USAG!
Report on module OVR1, "Code overlay module"
ABA..................................... : 7FE20067
Length (sectors)........................ : 100
Report on module IDNT, "HDD ID data module"
ABA..................................... : 7FE200D1
Firmware................................ : P22OABGA
Model................................... : Hitachi HDS721616PLA320
Serial.................................. : PVF974ZH0NULEN
Report on module CNSL, "HDD logical configuration module"
ABA..................................... : 7FE200CF
AutoReassign............................ : ON
Maximal LBA............................. : 312581807
Report on module MLBA, "HDD logical configuration module"
ABA..................................... : 7FE200D9
Capacity................................ : 312581808
Report on module ZONE, "Zone allocation table module"
ABA..................................... : 7FE200E1
Length (sectors)........................ : 3
Zones count............................. : 30
# Init. LBA Init. Cyl End Cyl SPC SPT
0 : 0 : 0 : 8191 : 53248 : 5
1 : 24376416 : 8192 : 15999 : 53248 : 5
2 : 47610048 : 16000 : 24447 : 40960 : 5
3 : 71937408 : 24448 : 29951 : 28672 : 5
4 : 87257760 : 29952 : 35199 : 28672 : 5
5 : 101866800 : 35200 : 38143 : 20480 : 5
6 : 109873120 : 38144 : 44415 : 10240 : 5
7 : 126429880 : 44416 : 50431 : 10240 : 5
8 : 142309480 : 50432 : 56959 : 0 : 5
9 : 159019880 : 56960 : 60031 : 60416 : 4
10 : 166760060 : 60032 : 62719 : 57344 : 4
11 : 173468060 : 62720 : 67327 : 45056 : 4
12 : 184526060 : 67328 : 71679 : 45056 : 4
13 : 194969660 : 71680 : 75391 : 32768 : 4
14 : 203520956 : 75392 : 77439 : 29696 : 4
15 : 208190396 : 77440 : 80255 : 24576 : 4
16 : 214497116 : 80256 : 85631 : 14336 : 4
17 : 226108196 : 85632 : 89343 : 4096 : 4
18 : 233828116 : 89344 : 92671 : 4096 : 4
19 : 240749316 : 92672 : 95743 : 61440 : 3
20 : 246941460 : 95744 : 100607 : 49152 : 3
21 : 256279380 : 100608 : 105087 : 49152 : 3
22 : 264880020 : 105088 : 109183 : 36864 : 3
23 : 272350212 : 109184 : 113791 : 28672 : 3
24 : 280459412 : 113792 : 118527 : 18432 : 3
25 : 288415052 : 118528 : 122751 : 8192 : 3
26 : 295172652 : 122752 : 126719 : 0 : 3
27 : 301266732 : 126720 : 130559 : 53248 : 2
28 : 306795612 : 130560 : 134143 : 53248 : 2
29 : 311955852 : 134144 : -1 : 40960 : 2
Report on module SRVM, "Module contains cylinder defects table"
ABA..................................... : 7FE200EA
Length (sectors)........................ : 16
Defects count........................... : 373
Report on module RDMT, "G-List module"
ABA..................................... : 7FE400E6
Length (sectors)........................ : 32
Header
Capacity................................ : 108
Defects count........................... : 0
Grown................................... : 0
Data:
Candidate............................... : 0
Total hidden (cand.).................... : 0
Total hidden (grown).................... : 0
Information about copy 1
Header
Data:
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded (RSVD, SA marker)
mu-code................................. : P2COEB9A
mu-code................................. : AB9A
Firmware................................ : P22OAB9A
Header
Capacity................................ : 1900
Data:
Information about common modules (Open+Spec)
Report on module SSSC, "Self Test management and status module"
ABA..................................... : 7FEA0009
Length (sectors)........................ : 5
Result.................................. : COMPFIN1
Error code.............................. : 0000
Filipp_TS
Re: Undetected Hitachi HDS721616PLA320 "Open Module Error"
Postby Filipp_TS » 15.03.16, 15:01
As you can see in log report - USAG module is not compatible with NVRAM.
mu code value should be the same in all modules and in NVRAM img.
dreu
Postby dreu » 19.04.18, 10:07
Filipp_TS wrote:As you can see in log report - USAG module is not compatible with NVRAM.
Even on a fully functional donor, the mu-code version does not match the modules.
Amarbir, did you resolve that case?
Postby Amarbir[CDR-Labs] » 13.05.18, 10:13
dreu wrote:Source of the post
Sure i did but not with acelab tool
italyassistance
Postby italyassistance » 22.03.24, 11:56
I have same problem whit HDS721616pla380 with fw AB0A P2C9TBEA but i dont found firware AB0A, Does anyone have it?
