I have one 8 GB SDHC monolith Card.
Top Side Marking is 4432cfq23426 008g
It is detectd in pc3000 flash tools as new chip 0x98DE9092-72500814.
in the data base their is similar type chips - toshiba 0x98de9892 found.
Try with it but not sucess.
Thanks,
Hemendra Shah
How to add New chip 0x98DE9092 Chip in flash
Re: How to add New chip 0x98DE9092 Chip in flash
ACE Lab can help you for adding chip into the flash database.
Thanks,
Amit Shah
Arihant Data Recovery, India
Amit Shah
Hi Guys ,
Always Wanted To Know More About Both Of You
Amarbir[CDR-Labs] wrote:Source of the post Hi Guys ,
PM you details
This chip has internal connection problems so it is wrong ID.
arvika wrote:Source of the post This chip has internal connection problems so it is wrong ID.
Arvika Sir ,
So How To Solve This Issue ?
I can't. If you have access to XRAY with very high resolution you can make photo and analyze where is the problem. Than try make cross. It will be hard and tricky job.
arvika wrote:Source of the post I can't. If you have access to XRAY with very high resolution you can make photo and analyze where is the problem. Than try make cross. It will be hard and tricky job.
Wow ,
Of course Removing that section layers and then exposing those points and jumpering them should be a very precise and complex job
