Please anyone has a rom+ldr for the below model:
Sabre53 Family
WD800BD-22JMA0
06-June-2005
SN: WMAM98102404
the native pcb is not available, i can try different version.
thanks in advance.
ROM+LDR Required: WD800BD-22JMA0
- GuideRecovery
Wasim Zafar
https://mindmergepk.com
Wasim Zafar
Re: ROM+LDR Required: WD800BD-22JMA0
Without knowing the consolidated ROM version no one is going to know which one it is. Just use any ROM/LDR combo from this family, read tracks, extract modules, etc. Maybe you have to try a few before you find one that has the correct SA regions. Then see if you can build ROM from SA or check it's own module 11 to see what consolidated ROM version it is after you extract modules.
GuideRecovery, there are a lot of FW resources for WD in HDDGuru forum: http://files.hddguru.com/download/PC-30 ... 20utility/
