hello, Seagate 250Gb 7200.12 firmware HP34 DRIVE SPIN WELL t> access well ,when try to erase alt list,smart, show this
Lawrence
Postby Lawrence » 25.02.16, 13:37
hello,
firmware HP34
DRIVE SPIN WELL t> access well ,when try to erase alt list,smart, show this error Failed to load overlay 00000004,
after try to read terminal via 1b sys file, smart file not read.. if try to read show this error
F3 T>
LED:000000CC FAddr:0028848
Rst 0x08M
No HOST FIS-ReadyStatusFlags 2002A185
Rst 0x08M
solution please help..
Re: hello, Seagate 250Gb 7200.12 firmware HP34 DRIVE SPIN WELL t> access well ,when try to erase alt list,smart, show t
Postby DataMedics » 25.02.16, 21:30
The drive isn't loading the translator. Try what's suggested in this blog post on Ace website: http://blog.acelab.eu.com/pc-3000-h ... error.html
Lawrence
Postby Lawrence » 27.02.16, 08:28
yes we try blog video instructions, when try to load transltor, show rw error..
Postby DataMedics » 27.02.16, 14:17
Check for NRG, so long as it's empty try regenerating the translator. If that fails, might be time to stick a fork in it :)
Also, even before that, you might give a try to reading all the critical modules through terminal using single sector read. You may find that between the two copies you'll get it all read and can assemble a complete system file that you can write back and restore it.
Filipp_TS
Postby Filipp_TS » 02.03.16, 08:58
yes, pay attention to following critical sys files: Translator, NRGlist, Plist. Need to create a backup of them through terminal
