Kingston SD 32Gb on PS8210-0
Typical Flash recovery cases
Marek
Postby Marek » 05.02.16, 22:31
I have a SD Card with PS8210-0 controler (Xor ID : 1585 in Flash)
I Read The dump (one chip witch two dumps)
- I have found ECC
- Correct error via ECC
- create a submap via invalid sectors
- i rereaded sectors success
- implemented xor and doing a block rotation
- in raw recovery i found many MOV files but corrupt
Please any advice?
Best Regards
Re: Kingston SD 32Gb on PS8210-0
Postby Roman_TS » 08.02.16, 08:01
Marek wrote:Source of the post
Best Regards
Hello Marek! Right now Image Building of PS8210 is very complicated - translation of blocks is not simple. Anyway, if you want, we can check your case in ticket system. Just create a new one - and I will check it.
Marek
Postby Marek » 08.02.16, 08:38
Hello Roman :)
I send via mail to ts@... about this case :)
Marek
Ticket: #32348
Postby Roman_TS » 08.02.16, 10:54
At this moment case not solvable. We have XOR but special algorythm for block rotation PS8210 is not working with MLC chips (right now - only TLC are supported). Without correct block rotation algorythm, image building will not provide good result.
Marek
Postby Marek » 08.02.16, 11:34
Thanks :) For Answer :)
Regards :)
Postby Amarbir[CDR-Labs] » 30.04.16, 09:51
Marek wrote:Source of the post Thanks :) For Answer :)
Regards :)
Marek ,
Can You Post a Picture Please I Am Interested To See How This SD Card Looks Incase i Get It In future
Marek
Postby Marek » 17.05.16, 10:49
Like this
