SSD 128GB SanDisk mSATA
Marek
Postby Marek » 27.01.16, 10:45
I have case with Sandisk Controller "20-82-00270-1"
SDSA5JK-128G 54-90-20854-128G
When I connect it to PC (PC3K Express) and without PC3K - SSD is recognized as 119GB Capacity
But When i try to go deeper to Drive - CRC error on PC3K and witchout PC3K...
Any ideas to reach the data on this SSD??
Best Regards
Marek
Re: SSD 128GB SanDisk mSATA
Postby Roman_TS » 27.01.16, 17:23
Hello Marek. This drive is not supported, so we can't tell you exact step how to fix it or repair. Just do not have enough experience with it :(
ketil
Postby ketil » 23.02.16, 09:55
I have a similar disk, SDSA5DK-128G. It is password protected. Do you know if/when you will get any SanDisk support?
Postby Roman_TS » 23.02.16, 15:30
Hello! We have a plans for adding Sandisk drives in support list. But we will start to support only Marvell based models of Sandisk drives. About native Sandisk I'm not sure.
Marek
Postby Marek » 25.02.16, 09:37
Ok. How about Lite-ON SSD on Marvell controller?? Will be support to ?
Postby Roman_TS » 25.02.16, 14:08
Yes, they will be add too but a little bit later.
lcoughey
Postby lcoughey » 11.03.16, 17:29
Roman_TS wrote:Source of the post Hello! We have a plans for adding Sandisk drives in support list. But we will start to support only Marvell based models of Sandisk drives. About native Sandisk I'm not sure.
Do you have an ETA on when we might see an update with this support?
Postby Roman_TS » 15.03.16, 07:57
lcoughey wrote:Source of the post Do you have an ETA on when we might see an update with this support?
Keep watching our news. I hope - it will happen in next 6 month.
recuperodatos.com
Postby recuperodatos.com » 02.06.18, 17:52
A have de same disck
Model: SDSA5DK-128G-2104 54-90-20811-128G
Controller: 20-82-00270-1
With the same problem.
Still no solution?
Best Regards
Adrian
Adrian Francisconi
Data Recovery Engineer
https://recuperodatos.com
Postby Roman_TS » 06.06.18, 20:16
All supported drives your can find in our list:
http://blog.acelab.eu.com/pc-3000-s ... dated.html
Return to “Other SSD”
