Power-off and power-on cycle on USB
recovery
Postby recovery » 25.01.16, 16:42
I search tools to do a power-off cycle for USB devices like WD/Samsung or other USB devices. I imagine a tool to connect USB devices to SATA port of PC3000, then make a copy with DataExtractor. Do you have an idea about such tools?
Re: Power-off and power-on cycle on USB
Postby DataMedics » 25.01.16, 17:32
recovery wrote:Source of the post Hello,
Why not just convert the PCB to a compatible SATA one? It's just a quick ROM transfer. And no, no such tools exist. The method of communication via USB and SATA are very different, so a simple converter like that still won't help anything as you'd still be limited by what you can do over USB.
recovery
Postby recovery » 25.01.16, 17:41
For an USB 3 PCB, I thought we cannot find a compatible SATA PCB. I will search more :wink:
lcoughey
Postby lcoughey » 25.01.16, 18:51
The only tool that I know that can handle power cycling USB devices is a DeepSpar Disk Imager with the USB add-on.
Postby DataMedics » 25.01.16, 21:00
recovery wrote:Source of the post For an USB 3 PCB, I thought we cannot find a compatible SATA PCB. I will search more :wink:
Just post the board number 2060-771XXXX and I can tell you which one to use.
Postby DataMedics » 25.01.16, 21:01
lcoughey wrote:Source of the post The only tool that I know that can handle power cycling USB devices is a DeepSpar Disk Imager with the USB add-on.
Even that really never works, I've yet to see it actually see it power cycle a USB drive. I asked DeepSpar about it, and they said it can't. I don't know.
recovery
Postby recovery » 26.01.16, 09:29
The PCB is 771949.
I can buy a 771959 or a 771931 I think.
Postby DataMedics » 26.01.16, 18:29
771959 is the board you need.
Maxim_TS
Postby Maxim_TS » 29.01.16, 14:09
Hello Everybody,
There is a list of known USB - SATA compatible boards here at forum, please look: viewtopic.php?f=155&t=8376&p=29087#p29087
Filipp_TS
Postby Filipp_TS » 08.02.16, 09:01
USB reading/writing mode have a lot of restrictions and as result a lot of options are not available.
But if you need just to switch on|off power supply via USB..
I think that better to save a money: :wink:
Return to “WD USB”
